C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost by gear
Old May 13, 2009 | 11:23 AM
  #61
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Right now, I will only install them in house. Like I said, very complicated installation.
It mounts to the torque tube.
If you already have an Eboost, 650$ gets the switch plate, harness, relays, installed, and setup for you ready to go.
Old May 15, 2009 | 12:06 AM
  #62
jmoody66's Avatar
jmoody66
Default nice
oh....count me out.
Old Aug 29, 2009 | 04:52 AM
  #63
jondavidginger's Avatar
jondavidginger
7th Gear
Does anybody out there know how many different settings that are for an E-boost 2 on a TT set up? In an ideal world I would want one setting for low boost where every gear stays at 7 psi; I would want one setting for every gear to be in high boost like 15 psi; and I would also want a boost by gear mode. I would almost be fine with the default setting be boost by gear, as long as there is a manual override where I can chose a specific psi to fit my different street desires. Does anybody know if an E-boost can do that or if it is always in boost by gear mode?
Old Apr 20, 2010 | 07:58 AM
  #64
BAADC6's Avatar
BAADC6
Just curious. Has anyone been using this setup? How has it worked out. I will be on the road soon with new motor and TT with an APS 1000 booost controller. Any more info you guys can provide would be great.
Old Apr 20, 2010 | 09:05 AM
  #65
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
AMS1000 Rob
Old Apr 20, 2010 | 10:22 AM
  #66
jrubicon's Avatar
jrubicon
Boost by gear has been working fantastic for me. Power can be put to the ground in every gear (1st is still a little touchy )
Old Apr 20, 2010 | 01:41 PM
  #67
EdwardETraylorIII's Avatar
EdwardETraylorIII
Louis really has outdone himself with this setup... It's worth the money and the trip to LG, folks! If you make serious power and want to get it to the ground Boost By Gear is the ONLY way to go fast!
Old Apr 20, 2010 | 01:44 PM
  #68
TTZ06VETTE's Avatar
TTZ06VETTE
[QUOTE=jrubicon;1573817961]Boost by gear has been working fantastic for me. Power can be put to the ground in every gear (1st is still a little touchy )
Just saw you live in Charlotte...would love to see your Boost by Gear setup in person as I already have the Eboost controller configured by RPM. Interested in determining the cost vs. benefit of adding this.
You going to the next Cars and Coffee?
Old Apr 21, 2010 | 08:34 AM
  #69
BAADC6's Avatar
BAADC6
Originally Posted by Frans96ss
AMS1000 Rob
Do you know any qualified installers
Hurry up and get my car done
Old Apr 21, 2010 | 11:09 AM
  #70
Mfahhad's Avatar
Mfahhad
i have it on my car
i didnt install it
love that thing its awesome with out it i would put my car in a wall long time ago
Old Apr 30, 2010 | 04:03 PM
  #71
Former Vendor
I have a new solution for the guys wanting boost by gear. MUCH simpler to install, more of a MPH related system, however, still switches within a given MPH window for the EBoost 2.
Oh, its a 1/3 the price, and takes 1/2 as much time to install
The problem with the plate on the torque tube, is that it will fail. There is no room in there for the switch plate, so one instance of axle hop, and it will break a switch. It might not do it the first few times, but they will fail. There is simply not enough room.
My new system is mph based, switching the grounds for the Eboost, within each gear window. Pretty neat.
The other issue that I ran into with the actual gear based system- Say you set the car into spin- Naturally, a good wheel man would short shift to the next gear. However, with the old setup, it would toss you into the next higher boost window, causing more spin.
Now, you can set SP 1-4 to an actual MPH.
Louis
Old Apr 30, 2010 | 04:47 PM
  #72
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Thats great news!
Old Apr 30, 2010 | 11:09 PM
  #73
Tiago's Avatar
Tiago
Louis
Louis I need more info on this new setup!
I am having trouble with the switch plate on the tq tube, need a new solution! Let me know what you have to offer
Old Apr 30, 2010 | 11:22 PM
  #74
INTMD8's Avatar
0INTMD8
Former Vendor
Louis
Sounds interesting. Makes me think it would be neat to control duty cycle based off front/rear wheel speed difference. If you could adjust the gain vs % slip you could have some serious traction control ability.
Old May 1, 2010 | 01:19 AM
  #75
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Louis
Thats pretty badass Louis!! I may holler at you soon about this
Old May 1, 2010 | 01:13 PM
  #76
Former Vendor
I think I have your number, if not, Im sure one of the DR guys has it. Ill call you.
Ill try to post a working video in the next few days.
Louis
Old May 1, 2010 | 01:15 PM
  #77
Former Vendor
I can do that. Im fortunate to have some very talented electrical engineers that work with me and are truly passionate about what we do.
To Boost by gear
Old May 1, 2010 | 06:27 PM
  #78
TTZ06VETTE's Avatar
TTZ06VETTE
Louis
Old May 1, 2010 | 08:34 PM
  #79
Rob@ChampionMotors's Avatar
0Rob@ChampionMotors
Former Vendor
I thought some of you might like this. Plates are being cut and harnesses are close to completion.
This works with the E-Boost 2 and allows Set points to be changed per gear, thus allowing an increase in boost for each gear.
Louis this a god send for us Turbo street guys. Please PM me on price for our shop car.
Rob.
Old May 2, 2010 | 10:44 AM
  #80
Skunkworks's Avatar
Skunkworks
Don't think you can easily adapt any off the shelf boost controller to do what you are describing.... First wheel sensors do not generate a signal that is either 12V or 5V (I'm sure you know that), so signal conditioning is required to convert sensor output to something CPU (boost controller) can understand. Also you'd need to measure pulse time very accurately, down to us (microsecond) which should be done in hardware...
Then adjusting gain vs slip if a fixed constant or similar, will work only in a given range.
A practical example would be a heating control loop for say a 5000 gallon tank. You have the control loop dialed in (PID loop gains) at 80% full (4000 gallons). Then you fill to 2000 gallons and notice you get a huge overshoot. This is normal for simple or a classic PID loop equation...
The reason I brought above example up is, if you got it working pretty well in say 2nd gear, by 4th gear it would likely not be sensitive enough (do to lower rate of change - ie speed delta rise of front tire vs rear). It's like hitting a constantly changing target, which it is.
Not saying it can't be done, just saying it's beyond the control algorithms found in off the shelf boost controller.
Mike
Fixed typo - didn't have morning coffee yet.
