C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost by gear
Old Jan 25, 2009 | 02:25 PM
  #41
adam205348's Avatar
adam205348
Originally Posted by PowerLabs
No its not... The blower is a positive displacement pump; it will FORCE X amount of air per revolution; if the throttle plate closes that air will have nowhere to go and something will give; either the blower will push itself off the intake manifold or the throttle blade will bend. Maximum pressure differentials for twin screw superchargers is a lot more than just 1 atmosphere
Can you clarify on how this is possible since the throttle body/thottle blade is before the supercharger. So you are saying without the recirc valve the supercharger would infact pull so much vaccumm on the thorttle blade that it would bend it?
Old Jan 25, 2009 | 02:33 PM
  #42
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Oh! Sorry, my comment was for blowers located prior to the supercharger. You are right, if the throttle plate is before the blower that doesn't apply.
Old Jan 25, 2009 | 06:02 PM
  #43
Skunkworks's Avatar
Skunkworks
Okay, I'll give this another try...
You have two mechanically coupled volumetric pumps, a blower feeding a engine. For each revolution the blower will move x amount of mass flow and engine will ingest x amount of mass flow. So if your throttle body is closed or at idle position, the blower is receiving a fraction of the flow it is capable of moving or pumping, but engine has no problem taking it away (less recirc valve), so you are still in vacuum.
Your quote above makes me think, that you are not taking into consideration either upstream throttle or engine running and blower not dead heading? Look at draw through systems (roots - 6-71, 8-71, 10-71 (with carbs), centri, turbo) they do just fine without recirc valve.
Mike
EDIT - Should have read 3rd page. Answered above.
Old Feb 3, 2009 | 07:20 PM
  #44
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Plates are being shipped today, should arrive late this week, I will be attaching harnesses and switches shortly after, and then once i have a few built, we will be taking orders
I have a few PMs to tend to regarding this product, but I wanted to get a little further along in the production timeline before I committed to anything
Louis
Old Feb 4, 2009 | 09:38 AM
  #45
Mr.Big's Avatar
Mr.Big
Originally Posted by Louis @ LG Motorsports
Plates are being shipped today, should arrive late this week, I will be attaching harnesses and switches shortly after...
Louis
Old Feb 4, 2009 | 11:14 AM
  #46
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Louis,
I may have skimmed over it, but is this boost by gear only for the C6 or will it work with a C5 APS car also?
Old Feb 4, 2009 | 01:54 PM
  #47
Vadian's Avatar
Vadian
Eventually he'll have one for the C5
Originally Posted by Corvette-Chris
Louis,
Originally Posted by Vadian
Any plans for something similar for the C5?
Yessir, I hope to have it tested in one soon
Old May 7, 2009 | 05:07 PM
  #48
jmoody66's Avatar
jmoody66
Default Im interested
I thought some of you might like this. Plates are being cut and harnesses are close to completion.
This works with the E-Boost 2 and allows Set points to be changed per gear, thus allowing an increase in boost for each gear.
Im waiting on my car as we speak, tune almost done but will be breaking in engine and clutch. Would like to know what you are charging to install and setup the Eboost2. I already have the unit new in box but just need to get it all set up. My car is an 02 Z06 with STS GT32's pushing 14lbs.
Old May 8, 2009 | 12:57 AM
  #49
427silverhotrod's Avatar
427silverhotrod
Think I need one of these.
Old May 8, 2009 | 05:05 PM
  #50
KWIKSS's Avatar
KWIKSS
Is this an add on to the Eboost2 or is it already set up in the Eboost2? I have a camaro and need this. Thanks
Old May 8, 2009 | 05:07 PM
  #51
adam205348's Avatar
adam205348
Eboost2 has it built in to have pre-set boost levels you will just need some way to activate each setting which is what LG has come up with.
Old May 8, 2009 | 08:53 PM
  #52
KWIKSS's Avatar
KWIKSS
Price??
Old May 9, 2009 | 03:43 PM
  #53
jmoody66's Avatar
jmoody66
Default nothing new
Others have figured out a way to do the same thing using microswitches from Radio Shack but the smart ones are making it very simple and marketing it to fellas like me that are too lazy to do all that work........I cant wait to get mine.....HURRRY UP LG!
Old May 9, 2009 | 07:31 PM
  #54
adam205348's Avatar
adam205348
yeah i know others have come up with same thing but dont want take away from LG's thread.
Old May 10, 2009 | 11:39 PM
  #55
Former Vendor
I have no orders for any Boost by Gear setups. They are very complicated pieces, and as such, I make sure its what the customer needs. I suggest professional installation if its available, as there are many small nuances with ANY BBG setup and installation.
Louis
Old May 10, 2009 | 11:55 PM
  #56
jmoody66's Avatar
jmoody66
Louis,
Im waiting on your pricing....I need this setup.
Jerry
Old May 11, 2009 | 01:50 PM
  #57
deviant1's Avatar
deviant1
Louis
any updates on a supercharged application?
To Boost by gear
Old May 11, 2009 | 01:58 PM
  #58
KWIKSS's Avatar
KWIKSS
Sounds very sweet. Price??? and where does it mount(or too). Inside tranny with the shifter?? and how much would an install price be.
Old May 11, 2009 | 03:51 PM
  #59
eric04's Avatar
eric04
Old May 12, 2009 | 06:08 PM
  #60
jmoody66's Avatar
jmoody66
Default cornfused
Louis
Lous,
Are you saying that you need orders in order to make it happen? Some of us are waiting on pricing so we know if we want to make it part of our plans....learn me
Jerry
