38 mph in the back half is moving pretty dam fast
maybe try and take a little power out
I wonder about the whole "less is more" idea in these cars.... I see what Rickey Bobby did with considerably less power, but I think track prep makes the difference as well.
The only pro event track I have been to was at the LSX shootout and they wouldn't let me go wide open.
The problem is, even on my fast runs, I am not turned all the way up and I am still trying to push through FULL exhaust and 18x10's up front! I also had the first run of the M&H's that only had an 11" contact patch vs. the new ones that have a 12"+ contact patch.
Next time out I think pushing skinnies, removing mufflers, and the new tires should make a difference, along with taking out just a bit of weight.
I would imagine these changes on a well prepped track would make for 8.50's @ 160+ without even hittin the N20 (never used it yet). Imagine if I actually get enough traction to spray it
I dunno if you have "the old" or "new" M&H's... But if you try the new MT ET Stret Radial Pro's.... I think you will be able to get a wee bit more tracdtion.
1) How many passes post build did it take you guys to get to 8.81?
2) How did you correct the stagging issues that were causing the lights to trip?
3) How much N20 was used on the Launch to push through the convertor?
4) Who was driving for the 8.81 pass and how long has that person been racing?
5) Are you guys planning on coming to the NMCA event or to a Private Corvette shootout if we get one together?
Thanks in advance.
1) 3 passes after auto swap 1st was a 1/8 shut down 2nd 9.35 next day went on a 30 mile run back to the track cool down 3rd pass 8.89 4th 8.81 2) walk over ran hand over beam and went from there 3) No nos was used at all I dont even have a kit 4) I was the driver not a pro by no means a pro 5) NO/and yes
Thanks for the replies, just trying to figure out what I may be doing wrong. 1.32 is really good for a novice driver. Was actually hoping he had been driving for a while so I would feel so bad about only hitting 1.42.
Reguardless Great runs and I can't wait to run side by side with you guys.
I personally doubt you were spinning in the back half Atomic (Mark?), but very possible for the first 1/3.
FWIW my YSi combo was easier to launch than my subsequent turbo combo.
Only blower car I have ever raced was LPFSTheFett's 06 Viper. That was a different launch all together with the 6 speed. Power came on differently as well.
And yes my name is Mark.. I think I met you at the LSX Shootout if I remember correctly.
Well, I don't really want to add a cage, but what it comes down to is I like to race!
I'm tired of 1 and done or waiting for track rentals that are 4+ hours away. We got the rule book out and I think we can get the car to pass tech down to 8.50. For full boost we will still be illegal, but at least on waste gates I'll be able to compete.
Currently on waste gates my car runs 9.8x@140 if I baby it out on full sized tires and don't lock up. I have to hit the breaks to stay slower than 10.0.
I don't think a C6Z can be made NHRA legal , the cage has to be welded to the frame , the frame is aluminum , how do you weld chrome-moly or mild steel to aluminum ? Don't think that's possible . A better choice for a 1/4 mile car is a regular C6 , no aluminum frame , and you could always put a Z06 body kit on it .
I think alot of the 60 ft has to be the way the power comes on with a blower versus the turbo. When I had my 347 the car would pull mid 1.4's leaving off idle-this was on MT ET Streets but it was only a 26" tall tire.
Are leaving with any boost off the line?
No we are not leaving on any boost. Those runs were leaving at like 1400rpm
My post was directed to Atomic Fran, centri cars react totaly different than turbo cars do on and off boost-which I'm sure you know and it's still why I'm a diehard blower guy.
My bosses C5 TTix car ran 9.7's@150+ this summer with a six-speed. Hi sixty foot was only in the 1.6's I believe but the car was only dialed in at around 850 rwhp.
Atomic have you thought about tightening up the stall or have you logged how long you spend in first gear and how much boost you see? From the vid's I saw of your car it and the other Yellow C6Z like yours it doesn't look like you guys get into wot too much in first gear?
Whatever the case is you guys are damn impressive in my books!
Well said Arun . A supercharged car doesn't need a transbrake , so the term leaving off idle is nothing special , in fact I think if you use a transbrake in an SC car you'll probably blow the tires off . A turbo car must use a transbrake to build boost , it's a lot harder to launch properly and takes a good boost controller to dial it in right .
Talk to any drag racer that has used more than one stall speed converter and size of converter and the 60ft and ET will be all over the place. This is a BIG BIG BIG part if you are trying to set low ET with your setup. Just my 2cents been there done that!
I agree with you there! I called Precision a little while ago and asked if they could change the STR on my converter-the guy on the phone laughed at me. He couldn't understand why I would want that? My stall's rated at 3200 but it easily flashes over 4000-so if they can't change the STR they're going to have to at least restall if for me.
I believe RickyBobby runs a Coan 10.5" single disc, I'm pretty sure on those runs it wasn't even locked as I don't think they can. I did talk to Greg over at Coan and he was pretty insightful as to what kind of stall would work for our cars-he sure got ti right on Ricky Bobby's car. Greg even said he would take apart the Precision and could fix it up-but he still thinks the 9.5" is too small.
I'm a bit more than a lurker right since I haven't replaced my C5Z yet but my old '98 Formula had a 8:1 348ci + a YSi + T400 and then the same block, different cam, + a 88mm T6 turbo + the same TH400 but with a different converter. The YSi setup preferred a big converter, I ran a 4500-5000 stall, came up on boost real fast, and launched hard even at lower rpms like 3000. The turbo setup I had (big turbo, small cubes) required bringing the rpms up before I even staged, and getting on the 'brake at the line was after foot stalling the crap out of it. I went 1.35 with both setups but they were totally different. I went 9.40@144 1.35 5.9 116mph with 680rwhp and 18 psi. I went 9.44@145 turbo 1.35 not sure the power level but it wanted to be shifted a lot higher.
I prefered the blower setup but since you run a 427ci + twins I'm sure the car has really strong mid range. My friend's 2002 TA has gone 8.2@168mph with twins and a 408ci.. Very easy to bring up on boost. Cubes make a huge difference.
Wow, tons of questions.... Ok, I will try to give enough info for all the discussion here.
1st off I can only stall to about 4k before the car starts pushing and normally have not really built up any boost to speak of by the time the lights start dropping. I think with a transbrake we could build more boost, but with the 4L60 we were worried that the trans would not hold the power.
I have a different stall than Rickey, and I do lock mine up. The last time at the track we actually lowered my 1-2 shift since the car was blowing the tires off in first so bad. When we had the earlier shift point the car had better traction. We are making some pretty big changes in this department with all the new information that has been learned.
With the auto, after the car builds boost, it holds it much better than many can with a stick (some are better than others).
As for the NHRA legality, we are supposed to hear a final answer tomorrow. If they cannot certify my car, I am not sure what I will do. It really serves no purpose to have a 8 second C6Z if I cannot race it competitivly.
Thanks for all the good info, lots of finishing touches going into the Z right now, and hopefully we will have it at the NMCA event on May 1 (NHRA certification will be the deciding factor).
What are you running for boost controller? Being able to adjust the ramp rate in 1st gear by either time or speed will be a huge help in bringing the 60ft down.
Twin 35r's on a 7.0 just light up too damn fast to get traction otherwise.
Also, fwiw I would not remove the mufflers. It's weight leveraged over the rear tires right where you need it and not a restriction at all if it is still the APS system.
