C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Is Boost-A-Pump needed???
Old Mar 22, 2009 | 03:18 PM
sixsixvette's Avatar
sixsixvette
Default Is Boost-A-Pump needed???
OK guys, this is what happened. I was cleaning up some of the wiring under the hood. The positive wire was accidentaly left loose and was resting against the header on my way home. It melted to the header and shorted out. Car went crazy and everything quit.
I found the wire and fixed it. When I tried to start the car I had zero fuel pressure. I checked the BAP fuses and they were good. I replaced the relay in the racetronics harness, but still no power. I removed the racetronics harness and hooked up the fuel pump "as factory". Car started right up and gave me 59PSI.
I figure the BAP got fried internally. Is there any danger in running the A&A kit without the BAP?? Do I need to replace this right away, or can I take my time and drive the car some without it???
The car is making 630 RWHP. I am running 60lb injectors and 7PSI of boost.
The car also in thowing out a "Service Charging System" message on the DIC. I have not solved that issue yet either if any of you have an idea. I did pull the alternator and had the local auto shop bench test it. It passed their tests, but I am not 100% sure it is good. Any suggestions???
Old Mar 22, 2009 | 06:21 PM
EuroRod's Avatar
EuroRod
I am running a ProCharger making 550rwhp, 60# injectors and I use the RaceTronics wiring harness that wires the alternator directly to the fuel pump(probably the same as your set up) but without the BAP. I have never had an issue with fuel pressure or lean conditions, so I think your okay to drive the car. I have the KB BAP, but did not install it on advice from by tuner. He has had too many fuel pumps burned out using it, so I passed on installing it. Good luck.
Old Mar 22, 2009 | 06:25 PM
NormWild's Avatar
NormWild
Both Procharger and Vortech say you don't need it. But it comes with the A&A and ECS kits and they recommend it. I'm confused as well. Mine goes in next week, and will probably try the tune without it. Any signs of leaning out and I'll put it on.
Old Mar 23, 2009 | 04:45 PM
EPP's Avatar
0EPP
Former Vendor
The very first ProCharger C6 kit we installed three years ago is shown here. We tried installing it without a boost a pump but the fuel pressure was dropping off too far, so we added the boost a pump which took care of it. It appears that some of these get by without needing the boost a pump, and other ones need it. http://www.exoticperformanceplus.com...Car.php?car=30 Bob
Old Mar 23, 2009 | 07:04 PM
nrotik's Avatar
nrotik
I just had the procharger kit installed on my ls3.. 62lb injectors without a bap..
Old Mar 24, 2009 | 01:34 PM
PcarRacr's Avatar
PcarRacr
I'd make sure it is in there. The last thing you need is the Alternator lowering the voltage while your at full boost and you get detonation that you don't even hear. I have the Vortech kit but have added a BAP for cheap insurance. I believe the C6Z06 Vortech kit is rated at 575whp so at that level I'm sure it is safe, however 630whp and 575whp are totally different and I would be caught dead running around on just the stock Fuel Pump at that HP level.
I'd get it fixed. A new BAP is much cheaper than new pistons
Old Mar 24, 2009 | 01:49 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
At 600WHP my fuel pressure drops up top WITH the BAP. I too would never chance running without one; they are cheap anyways.
Old Mar 24, 2009 | 03:42 PM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
I've seen this also depending on how fat the tune is...
Old Mar 24, 2009 | 05:32 PM
sixsixvette
Well, everything has worked out. My electrical problem was a blown fusable link in the alternator power cable. Since the BAP was getting its power from the Alt pos terminal, the break in the fusable link caused the BAP to not work. I installed a new cable and I suspect I can now put my BAP back in-line with the fuel pump and all will be well. The BAP is most likely fine!!
I did notice on a test drive that under full throttle my fuel pressure dropped from 60 PSI to just under 50 PSI! I do not think my pressure ever dropped more than 1 or 2 PSI when the BAP was installed and working. I think this is pretty good evidence that the BAP does its job!!
Thanks to everyone for the advice and help with my recent electrical issues!!
Old Mar 24, 2009 | 05:55 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You'll need somebody with a Tech 2 (Dealer or Shop) to figure out problem. The PCM is what controls the alternator charge rate.
Old Mar 24, 2009 | 06:43 PM
sixsixvette
I went old school on it!! I used an ohm meter and a schematic. Ended up being the alternator power cable that runs to the starter. This is the cable that shorted to the header. On the end near the starter is a fusable link. Within its insulation (could not visually see anything wrong) the fusable link had opened, but was intermittently making contact with high resistance. $6.42 later, problem solved! No codes and no other issues so far!
Old Mar 24, 2009 | 07:01 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Electrical problems are such a be-otch. I'd rather deal with mechanical issues any day.
Old Mar 24, 2009 | 09:48 PM
PowerLabs's Avatar
PowerLabs
They don't bother me... I swapped an engine into a car it didn't belong to, and had to re-do the entire wiring harness:
Wiring issues don't bother me as much because they are typically much CHEAPER to repair... When something mechanical breaks, you get to identify the problem and then buy a part to fix it.. With electrical issues a lot of times it is a short or a poor connection and even when something is burned out, those parts are cheap
Joke: All electronic components are actually made of compressed smoke. When the smoke leaks out, they stop working
Old Mar 24, 2009 | 10:01 PM
PowerLabs's Avatar
PowerLabs
You can see my fuel pressure Vs Boost Vs AFR Vs RPM on this chart:
You will notice that the fuel system wants to maintain a steady 60PSI.
At exactly 4PSI the BAP comes on creating a transient spike that stabilizes soon after (notice it causes no issues with the air/fuel ratio). From there the fuel pressure gradually drops, DESPITE the BAP, to 55PSI at redline.
This is a problem though because at redline the car is also under 10PSI boost, so the *effective* fuel pressure is only 45PSI.
My fuel injector duty cycle there is around 85% with 60lbs/hr injectors.
Old Mar 24, 2009 | 10:04 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Yeah, I agree most electrical problems are cheaper to fix but they are not fun to figure out.
BTW, Nice Pic's , I had similar problem with rear tail-light harness.
To Is Boost-A-Pump needed???
