C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Aps extreme fuel system
Old Mar 27, 2009 | 01:22 PM
vette113's Avatar
vette113
Default Aps extreme fuel system
Corey Henderson is installing an Extreme Fuel System from APS in my C6 corvette. It had the stock APS fuel system with the Kenne Belle Boost A Pump. Has anyone gone back and installed an Extreme Fuel system and if is, did you leave and use the Kenne Belle or remove it?
Old Mar 27, 2009 | 03:00 PM
07MontRedcp's Avatar
07MontRedcp
No need for a BAP with that fuel system. The BAP is used to boost the output of the stock pump.
BJK
Old Mar 27, 2009 | 03:35 PM
IPS Motorsports's Avatar
IPS Motorsports
You can leave the boost a pump if you like, it depends on the demanded output of fuel you need for your car, the two walbaros will not sustain safely much over the 1000 wheel horse power range, you will need additions to the system if you are trying to achieve over this amount.
But if your only going for 8-9 hundred horsepower it works well.
-Brandon
Old Mar 27, 2009 | 05:38 PM
tjwong's Avatar
tjwong
-Brandon
Brandon what does that APS fuel system run for cost?
Old Mar 27, 2009 | 08:08 PM
vette113's Avatar
vette113
Is there a shop in Texas which has done several APS on C6 corvettes?
Old Mar 27, 2009 | 08:25 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Yes
leave the BAP.
Old Mar 28, 2009 | 05:23 AM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
Many ways to configure your fuel system depending on your goals and pocket book.
Old Mar 28, 2009 | 11:47 AM
vette113's Avatar
vette113
Louis, why do you leave the BAP when doing an Extreme Fuel System on a C6 APS system? What can it offer in backup, safety, performance, etc? Can you share this?
Old Mar 28, 2009 | 12:44 PM
Former Vendor
Because if you ever max that system out, its very easy to use the BAP to extend the fuel system with out changing out hardware. Real quick, real easy, its already on the car, leave it.
Is it necessary? No. Leave it turned down, and if you need it, you can use it!
Would I install one WITH the extreme system? No. Your case is different than most
Old Mar 28, 2009 | 02:07 PM
Former Vendor
I'd have to agree...
Old Mar 28, 2009 | 10:15 PM
vette113's Avatar
vette113
Thanks, Louis. Appreciate your comments and they make good sense. Will leave in.
Old Mar 29, 2009 | 11:30 AM
IPS Motorsports
Right on key, we most recently used this idealogy on a high output supercharger car, with a similarly designed in tank system.
I do however like the idea of a surge tank properly sized with flow capacity to maintain constant and consistent fuel pressure. Lou has a system like this for sale, and there are many shops as well who create these (including ourselves) on a case basis.
Also please remember as the demand for voltage and amperage in the car increase with all the added fuel pumps, comes a larger demand on the charging system, another point of influence.
-Brandon
To Aps extreme fuel system
