Procharger Heat Issues
I previously saw on the forum some issues about Procharger heat in the C6's since the single, big intercooler sits so dang close to the radiator. I know some people did modifications to the radiator support brace to allow the bottom of the intercooler to tilt forward a couple inches, but I believe those posts have been removed.
I really need to do something soon. I was seeing average oil temps of around 232-234F just driving at 73 mph with the cruise on today. Temperature outside was 94F. I didn't look at coolant temperatures too much, but I'd say they were probably around 210F most of the day (took a 3 hour drive from Atlantic City up to New York today and had the same temps on the way down two days ago).
If any of you have pictures and/or specific information about the modificaiton I mentioned earlier or if you have any other modification ideas, please post up on the forum. Any kind of help would be much appreciated. Thanks.
I've always read on this forum to search for "Big Bollas Mods" for the Procharger... Maybe you could try that?
For those of you who haven't seen the thread or can't find it b/c it's been buried, here it is:
"How to Kill the Procharger Heat Monster"
http://forums.corvetteforum.com/c6-f...t-monster.html
Thanks!
Procharger has been very good about listening to their customers and modding their system to higher levels of efficiency. If you have the newer version of their kit thse issues have been addressed with the new cradle
Are these temp actually that bad? oil 232, coolant 210.... My A A will get that high as well with 95 degree heat and spirited driving as well. These are actually max numbers for me as I never not seen anything higher.
What number is too high for oil??
And yes, I smoked him.
230's on the oil temp is FINE , its when it goes into the 26-270's and higher you need to start getting concerned . However , it should not be reading that high when just cruising at 70 mph , but thats the nature of the beast with the Procharger .
There are a number of things you can do to get it under control - I had the same issues on my old 07 that was Procharged as well . What I did was as follows .
Clean the intercooler and radiotor regularly ( pressurized air and water ). THIS IS A HUGE ISSUE , and I would do it at least once a month , you woudnt believe the **** that gets trapped in there . I also had the Vette Doctors remove my radiator and intercooler and clean them from the inside . A tremendous amount of dirt came out of them , but its an expensive service .
The Bollas mod where you angle the intercooler all the way out .
Cut the top of the air dam to allow more airflow ( made a huge differance )
Ran straight Watter Wetter ( helped a little ) .
Good luck
Anyway, I've been driving the car in various conditions (ex. stop/go traffic, high speed runs, mountain blasts, etc. FWIW ambient temp has been in the 90's here since we installed it. I think the old issues were solved with the new rad. support. I couldn't be happier with this setup and it's the third C6Z with a D-1SC procharger we've messed with!
p.s. I do have a boost Q that I'll start another thread about though
M
M
Bob
