Supercharger affect front suspension/handling?
with the added 70 ~ 80lbs (either A&A, ECS or Maggie) and higher center of gravity on the front (Maggie), do any of you notice any difference in suspension height or change in handling?
thanks for chiming guys/gals
Location: Greater Detroit Metro MI, when I'm not travelling.
Its a 3300 lbs+ car with you in it. A set of headers will drop approx. 20lbs from the engine, so when you add a 70lbs blower, you have 50 extra pounds or so at the front; you will notice that the front end does drop some with the blower in place (I had to re-adjusted my ride height after that), but the actual balance of the car shifts by only 1%, which is not something you can notice, even when driving near the limit.
*numbers are approximate*:
Supercharger, installed: +-65LBS (you add the blower and intercooler, but remove the stock intake, stock idler pulley, stock radiator shroud and other misc. items)
Aftermarket Headers: -20lbs
Twin Disc Clutch: -20lbs
Braille lightweight battery, stock location: -20lbs
Braille lightweight battery, relocated to trunk: -17lbs, -53lbs for the sake of weight balance (stock battery weights 36lbs)
Stock battery in trunk: -72lbs (effectively for the sake of weight balance)
LG Coilovers: -20lbs (Manufacturer claim)
Carbon Fiber driveshaft: -3lbs
Stock C6 seats: 60lbs each (heated / side airbags), Aftermarket seats can remove 30lbs or more from the car depending on make and model.
My car:
Wheels/tires: -16lbs
Monster Stage 2.5 clutch: -16lbs
American Racing 1 7/8" headers: -18lbs
*soon*:
Optima 34 in trunk: -10lbs, 46lbs effective.
Lightweight 2 piece rotors: -12lbs
So my car will weight approximately 7lbs less than stock
And the weight bias will be shifted to the BACK by 15lbs as compared to a stock C6 (which does have a slight front weight bias from the factory).
Without removing anthing and making no sacrifices in comfort...
My car:
*soon*:
For what its worth though, I must point out that my car does hook up a little better on a full tank That's part of my motivation for moving the battey to the trunk...
1 Post
Once you raise it back up its negligible, but certainly more then half a tank of gas unless you shed weight elsewhere.
Mike
I have the ECS 1500 kit, it's about 60lbs. I did notice a little more scraping, very little. We raised the front end adjusters a few turns. As far as handling goes: What makes a HUGE difference is ripping out the toy factory C6 sway bars & putting in Hotchkis or similar. I also relocated the battery to the rear pass cargo area. (I like both these mods a lot)
St. Jude Donor '09
Sam, you would probably have to add at least 110 pounds to your weight, which isn't bad considering your supercharger and 2LT. Your headers definately saved you some weight. I'm just now starting to get into the weight game with this car.
I think one thing that is nearly as important as weight is weight distribution.
San
