Techco supercharger released, video inside
oh.... STOCK HOOD!!!!!!!!!!!!
TECHCO 3.0L REVERSE REVOLUTION
TWIN SCREW SUPERCHARGER™
(2005-Current Chevrolet Corvette)
TECHCO announces the release of their flagship 3.0L Reverse-Revolution Twin Screw Supercharger for the 2005-Current Chevrolet Corvette. TECHCO engineered a 3.0L Twin Screw Supercharger from scratch and designed the reverse rotor lobes to allow for a front inlet induction. This revolutionary Supercharger was first released for Dodge 6.1L and 5.7L HEMI engines and Ford Mustang 4.6L. The TECHCO Supercharger Kit for the Corvette utilizes the largest Supercharger (3.0L) and Intercooler System (118.4 in2) with the most horsepower (585hp) per lb of boost available on the market today, while fitting underneath the factory hood.
Key Features of The TECHCO Reverse-Revolution Twin Screw Supercharger™:
• Reverse-Revolution Twin Screw Compressor with Asymmetric Multi-Lobe Screws
• 3.0L / 180 cu. in. Displacement
• Front Inlet Induction with Integrated Bypass
• 9.5 Inch Long High Flow Intake Runners
• Dual Stage Intercooler System with Single-Pass Coolant Flow through the (2) A-Frame Intercoolers (118.4 Sq. Inch area), Large Capacity Heat Exchanger, High Volume Intercooler Pump and Recovery Tank
• Open Element Cold Air Kit with High-Flow Air Filter with Venturi and High Flow Inlet Tube
• 110mm Billet Aluminum Oval MAFS Housing
• High Volume Extruded Aluminum Fuel Rails with upgraded 54lb/hr fuel injectors
• 8-Rib FEAD (Front End Accessory Drive) with SFI Damper
• Ultra-Light Weight Aluminum Extrusions utilized throughout the design
• Diablo Predator Flash Programmer with TECHCO Calibration
• Detailed Instruction Manual
$8,500.00
http://www.youtube.com/watch?v=dWjwAa-1Gjc
Thanks!
at 14 psi (engine is only a 5 liter)
We have done a bunch of 6.1 liter dodges with BIG torque (the dodge runs really low duration cams stock and run out of steam before 6k) these are over 600 rwtrq. Are the #s you are lookign for rear wheel or crankshaft?
The SC will do it easy and all day as it keeps the heat build up way down.
I will be doing LG long tubes, no cats, 3" pipes into cutouts, tuned on Meth and I can of Torco per tank of gas to raise the octane. It will have an agressive tune on it as well (Charlie at RPM). My goal on the stock block with Charlies tuning is 700 rwhp and 600-625 rwtq. Basically I'm trying to replicate what a bunch of guys ghave done with ECS centri blower on the stock block.
On the centrifugal side most guys are making 550 - 600RWHP at 500 - 550RWHP with some making a lot more...
If your kit can match (not even beat) the numbers other kits are making while fitting under the stock hood and with that awesome twin screw torque curve, it would be a real winner in my book
