C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Forced Induction Z06
Old Jun 18, 2009 | 06:24 PM
Jutskin's Avatar
Jutskin
thicker head gaskets, methanol, & a good tune with limited boost could work....
engine goes south and you build your new FI focused build with the coin you were able to save by not spending for a half job now.
Just my 0.02...might not be perfect...but an option nonetheless.
If used parts were worth anything I would give different advise.
Old Jun 18, 2009 | 06:31 PM
kumar75150's Avatar
kumar75150
its cheap to put a piston in a lsx motor
i wouldnt spend the money on headwork just to drop compression half a point
Old Jun 18, 2009 | 06:32 PM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
You got that part right!
Old Jun 18, 2009 | 07:02 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
Originally Posted by Earl H
...been seing this in a few places re: re-sleeving the block. I have been running an LS7 block for some time...even had a rebuild on it, with no problems. How many guys have been blowing thru LS7 blocks? Not sure it the block is a real issue up to monster hp levels. Maybe applicable/maybe not...but kinda' of reminds me when everyone was advising guys to go wth new cranks when the LS1's first came out...years later, guys are running 8's and 9's on the stock cranks. I do agree on the pistons though.
yes you can get away with not resleeving the block, and i quite sure your is doing fine, but i have also seen guys first hand crack the sleeve on factory motor with just a tune, mind you i feel the tune was probably no safe, but it goes to show you the brittleness of the "press-in" factory grey iron sleeve, unlike the other ls blocks which feature a cast in grey iron sleeve which have much more metal around the sleeve to support the sleeve. all that being said, i feel it a wise investment to just upgrade to a ductile iron sleeve while your rebuilding the motor. that is just my opinion that i base off my experience
Old Jun 18, 2009 | 07:31 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
How many people here, have actually broken a stock piston on boost alone?
Old Jun 18, 2009 | 08:07 PM
Mr.Big's Avatar
Mr.Big
Old Jun 19, 2009 | 09:11 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by Mr.Big
Like Doug said...
first things first... What is your h.p. goal, and what is the intended use for the car?
I'm surprised this still has not been covered?
We have several 650-700rwhp bone stock LS7's roaming around that way. Granted it is discussed that there are no guaranty's at that level, but they are all happy so far, and for some time now.
Um..... do enough and eventually... Of course 17-18lbs on a stock piston might be part of the problem, but it did take almost two years of hard racing at that, and we have only broke one LS2 C6 so far.
Old Jun 19, 2009 | 09:29 AM
Z06.R's Avatar
Z06.R
Could some of the engine builders/tuners give an approximate cost for installing a set of forged pistons in a Z06, and what comfortable power levels would this allow?
Old Jun 19, 2009 | 11:02 AM
Former Vendor
So, all of the speculation here, no one has yet to fail a stock LS7 piston?
Sure, going to a forged piston is correct, but everyone here is crying wolf, yet no one has seen the wolf?
All of my builds, save for cars on the gates only get 100% built engines, sleeved blocks, etc. All of them have made over 900 rwhp.
Im not in the business to chance someones engine, unless its their prerogative.
Guy simply asked if there were larger chambers available. I have that. Everyone else is screaming pistons for a simple low boost kit
Old Jun 19, 2009 | 12:12 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
There was a customer of ours in Puerto Rico who was a 800 or so on the stock LS7 and it let go eventually.... i'll try to dig up the specifics...
Old Jun 19, 2009 | 01:49 PM
Z06.R's Avatar
Z06.R
http://forums.corvetteforum.com/1570389493-post18.html
Not boosted, but still a failure. And also another one in the linked thread.
Old Jun 19, 2009 | 02:43 PM
Former Vendor
I responded when that thread popped up.
FI tunes are usually WAY more conservative, than a track car on the Ragged edge.
So now that this thread has derailed, whats the OP going to do?
Old Jun 19, 2009 | 02:50 PM
  #33
Former Vendor
I can't speak for everyone but what I was saying is that it is un-necessary to lower compression on this combination to get very desirable results.
Further, lowering the compression a half a point at most will net zero gain in reliability or longevity given the same result in power output.
I'm sure you agree with that.
Old Jul 15, 2010 | 09:32 AM
  #34
v8maro's Avatar
v8maro
I'm curious about this too...
Old Jul 15, 2010 | 12:08 PM
  #35
Former Vendor
Check this out:
http://forums.corvetteforum.com/c6-z...l-special.html
