I used to have an '02 Z06 with a A&A procharger on it with the dual core radiator. It would overheat after one lap at Road Atlanta. Has anyone come up with a solution to FI overheating issues for cars used on track days?
tia,
Jim
Although I can't speak from a road race perspective, I was running at 260* on the the road in stop/go traffic in our 95-100 degree North Carolina summer heat. Finally solved the problem with a different intercooler design that blocked less of the cooling area of the radiator(2 smaller units plumbed together vs. one large unit) and a 160* thermostat. Now I rarely surpass 200* even on the hottest days in traffic.
Thank you for the reply. I'll be living back in Florida next year so I'll be in the same heat you experience.
With A&A's design, I never had a problem in traffic but the large intercooler would block too much air going to the radiator. I'm wondering if the STS setup would be a good one to use.
AA has since redesigned their C6 intercooler setup so much more air reaches radiator/condensor. see latest design on their web page
woow
ask me this question about over heating ! damin man in My country the TEMP goes up to 50 Degree C
at night 45 42 in summer
its middle east Kuwait
what i will do now ,, which i already did ,,,
bought meizer electric Pump With thermo 160
and also after i install it ,, i will get FANS which HIGH CFM
but afte i try the electric water pump i will let you know ,,, i already ordered it from LG motorsports yesterday
I remember Andy said they had a kit that enclosed the area around the radiator allowing only one way for the air to go....through the radiator.
Steve, have you had any customers road track their cars and not have the overheating issues or should I resign myself to the fact that FI is just big power for the street and strip?
Thanks Steve!! Andy helped me make 712rwhp with my small 347 and an antiquated P1SC back in '05. You guys produce proven performance and outstanding CS. Just want to use that big power to walk some folks on the back straight at Road Atlanta on track days.
