C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Bottom end suggestions
Old Aug 9, 2009 | 05:38 PM
out2kayak's Avatar
out2kayak
Default Bottom end suggestions
Hey all,
I have a Warhawk block and am looking at different bottom end options. Am thinking of Oliver rods, Callies crankshaft (Dragonslayer), and JE pistons.
The goal is a bottom end that can handle 1500hp boosted (twin turbo).
Thoughts / suggestions / recommendations?
-- Joe
Old Aug 9, 2009 | 05:56 PM
Mr.Big's Avatar
Mr.Big
Joe,
the only change I would make would be the choice of crank shaft, I'd go Lunati pro series, Callies has had some issues with 1100+hp as of late...
Old Aug 9, 2009 | 08:58 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
Sounds like a question for your builder.
Old Aug 9, 2009 | 09:23 PM
tjwong's Avatar
tjwong
Originally Posted by Mr.Big
Joe,
Step up the Callies Magnum series crankshafts.
Old Aug 9, 2009 | 10:54 PM
Mr.Big's Avatar
Mr.Big
I would not purchase any crank from them right now, but that's just mho... too many issues...
Old Aug 15, 2009 | 07:57 PM
hucktyson's Avatar
hucktyson
crower makes excellent cranks. if it was me i would use dyers 300m rods unless u went for the titanium crowers. je and mahale are what all the big name race engines builders use for pistons and i would absolutely find a way to install a 5 stage external dry sump with a well designed 3 gallon tank. the callies dragon slayer is ment to be an alternative to chineese import junk like eagle and scat it was never maent to be run in a 1500 hp motor.
To Bottom end suggestions
