C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost Question
Old Sep 17, 2009 | 12:34 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Originally Posted by Spying Beast
Don't get me wrong Dan, I have zero issues with the performance of the car, it's as fast as I can handle. I was just curious as to why the two types of blowers made boost at different rpms.
So Sam, by dropping the CR, does that make the stock motor more capable of handling higher boost levels without blowing up?
Ummm... Tricky question The simple answer is "yes":
Dropping the compression ratio makes any motor capable of handling more boost without detonating on pump gas
It also necessitates that you run more boost to make the same power you did before though, so, whether that makes it able to handle more POWER, is a different story... It would make safer power, but the absolute limit is still the stock internals if you prevent detonation through other means like Meth injection...
Old Sep 17, 2009 | 11:31 PM
Spying Beast's Avatar
Spying Beast
OK, that makes perfect sense....
I noticed that people who run turbos frequently run lower CR's. I'm guessing based on this threads educational direction that the reason for turbos requiring lower CR's has to do with the higher AIT then...?
Old Sep 17, 2009 | 11:34 PM
PowerLabs's Avatar
PowerLabs
Not necessarily; most turbos are actually more efficint than centrifugal superchargers... The guys running lower CR are just looking for big power numbers... All the "mild" turbo kits keep the engine stock just like base supercharger kits...
