C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Nitrous Experts Help!
Old Nov 19, 2009 | 08:48 PM
wanalooz's Avatar
wanalooz
Default Nitrous Experts Help!
I have my 06 z06 at a shop, installing a wet direct port nitrous system on my built engine. Is there anything I should mention to them before the install is complete.( If it was your car, what would you make sure was not left out)
Timing? Colder plugs? Run rich? Cylinder #7 should have a larger fuel jet?Progressive?Fuel?Safety?
Help me out,
Thanks Ed
Old Nov 19, 2009 | 10:15 PM
Drewstein's Avatar
Drewstein
Help me out,
Thanks Ed
Well you'll need the proper plugs, and a proper tune checked with a wide-band at least. I would personally make sure the car had a window switch on it as well as a fuel pressure safety switch.
My question to you would be; Why doesn't the shop installing the kit know this stuff already? That would be my concern.
Old Nov 20, 2009 | 07:02 AM
wanalooz's Avatar
wanalooz
I'm sure they do, I just want to make sure we don't miss anything. I am installing every gadget and safety item I can think of, any input is much appreciated.
Old Nov 20, 2009 | 07:19 AM
Mr.Big's Avatar
Mr.Big
one addition to the setup you've decided on, add a NANO assist, instead of a b.s. Heater...
Old Nov 20, 2009 | 08:23 AM
wanalooz's Avatar
wanalooz
Lsx intake, nano, progressive controller, direct port, dedicated fuel system, blow outs, gauges,blow down tube, purge, carbon fiber bottle, opener, filters, fuel rails, tires, 200-250 shot, hoping to break 9.99. If I left something out please add to the list.
Old Nov 20, 2009 | 09:23 AM
Drewstein's Avatar
Drewstein
What I said above -
Window switch
Fuel pressure safety switch
Plugs
Tune checked with a wide-band
GL on the quest for 9s
Old Nov 21, 2009 | 01:13 AM
Nitro Dave's Avatar
Nitro Dave
Sounds like you have a pretty good idea. Needing a larger fuel jet in number 7 should be determained by reading the spark plugs. I would not suggest using a larger fuel pill and not actually varifying by the plug its right.
Main things to concider other than parts area.
Fuel delivery, Airfuel, spark plug choice, timing.
Dave
Old Nov 21, 2009 | 09:16 AM
wanalooz's Avatar
wanalooz
Thanks Dave thats good to know about fuel jet in number 7, thanks for the feed back.
Ed
Old Nov 21, 2009 | 02:31 PM
J HEBERT's Avatar
J HEBERT
#7 will become less of a concern if u provide a coolant cross-over and tee in to the cross-over in the front. The #7 issue lies in coolant cavitaion/flow for the #7 cyl, NOT in airflow making that cyl. lean. Jetting #7 fatter helps, but is the band-aid IMHO
Old Nov 21, 2009 | 02:37 PM
J HEBERT's Avatar
J HEBERT
Good suggestion, but that bottle too will need filling, I will sometimes use 2 bottles tee-ed together both heated, this way we still have over 900psi at the end of the pass in high gear. NANO is very sweet though..
Old Nov 21, 2009 | 07:33 PM
wanalooz's Avatar
wanalooz
Thanks for all your info, who has the largest shot on a stock ls7 block, I heard that the 211 Texas mile guy has a 300 shot, is that the largest to date?
Old Nov 22, 2009 | 08:16 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
The Texas Mile guy is Mike Z. He had two kits, a plate and a stand alone direct port. I think it was total 350 shot, but I am not for sure.
To Nitrous Experts Help!
