C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Anyone use the AEM boost controller?
Old Dec 3, 2009 | 09:55 AM
SpinMonster's Avatar
SpinMonster
Default Anyone use the AEM boost controller?
http://www.aempower.com/ViewCategory.aspx?CategoryID=68
I like the compact nature of the gauge being the location for the boost amount.
I would like the ability to have 10psi in first and hit a button to increase it for subsequent gears (without silly pricing). Is there a boost controller that does this?
Old Dec 3, 2009 | 11:12 AM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Eboost2
Old Dec 3, 2009 | 11:21 AM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
http://www.dallasperformance.com/DPC...Gear/index.htm
Old Dec 3, 2009 | 12:44 PM
Corvettes of Dallas - Parts's Avatar
0Corvettes of Dallas - Parts
Former Vendor
Originally Posted by Louis @ LG Motorsports
Eboost2
e boost2 is great stuff!
Old Dec 3, 2009 | 05:13 PM
Dan Wendling's Avatar
Dan Wendling
Default E-Boost with a Centrifugal Supercharger
Spin:
Are you considering this for a centrifugal supercharger application?
I had started another thread on this topic but no responses from users with experience, simply to call Dallas Performance.
http://forums.corvetteforum.com/1572271929-post1.html
Seems to me like it would work with a SC as well as with a TC?
Old Dec 3, 2009 | 09:07 PM
Former Vendor
We built a Procharged vette with a EB2 and wastegate setup. Didn't work as well as I had hoped. My electronically adjustable restrictor plate method works much better.
Old Dec 3, 2009 | 11:55 PM
SpinMonster
Its for a TT kit.
Does anyone have a say on the AEM kit?
Old Dec 7, 2009 | 02:15 PM
forcefed281's Avatar
forcefed281
I had it on my 700hp dsm a couple years ago. I thought it was a POS, I ended up taking it out and used a standard $50 ball and spring manual boost controller instead (which worked just as good if not better). If you want an awesome boost controller with boost by gear, check out the AMS 1000 Boost controller.
Nick
Old Dec 7, 2009 | 04:17 PM
carlrx7's Avatar
carlrx7
i haven't personally tried this myself, but am curious, maybe you could try
in hptuners, goto the torque management tab, then general, and take a look at the Max engine Torque vs RPM vs Gear table. it uses the ETC to reduce torque
it comes maxed out stock.
if all your injector data is correct and all airflow is accounted for, then pcm can properly calculate the Tq of the motor.
so try adjusting the 1st gear colum to 200 and see if that does anything for you, then bump it up to the limit where you loose traction. some tables dont do squat in hptuners.
i haven't tried this myself, might be to good to be true.
-carl
p.s. just read it was for a TT, maybe a wastegate controller would be the best choice, like you've mentioned.
To Anyone use the AEM boost controller?
