your thoughts please
When turning at very slow speeds, things are beginning to clunk in the rear end.
Please give me your input on what I'm dealing with.
Thank you guys!
I posted it here because I'm in this club.......by the way...did anyone ever get the free t-shirts from procharger since this forum basically told them how to build their stuff..lol
I didn't get mine
Been working on Land Rovers for about a year, so I'm out of the loop.
Please explain updated oil. Is it something special that is considerably better than original factory oil? Not trying to be a smartass, I just haven't heard of it.
The Dexron LS Gear Oil 75W-90 is PN: 88862624. It has its own friction modifier built in. No need to add anything.
Document ID# 2048181
2005 - 2008 Chevrolet Corvette
Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns (Drain/Refill Rear Differential Fluid) #07-04-20-002A - (01/09/2008)
Models: 2004-2008 Cadillac XLR (Including V-Series and Export)
2005-2008 Chevrolet Corvette (Including Z06 and Export)
This bulletin is being revised to change the fluid recommendation and to remove the requirement of adding friction modifier. Please discard Corporate Bulletin Number 07-04-20-002 (Section 04 -- Driveline/Axle).
Condition
Some customers may comment on a clunk and/or chatter type noise from the rear of the vehicle while making turns.
Cause
This condition may be caused by slip/stick of the posi-traction clutch plates due to insufficient limited-slip axle additive. As plates slip and stick, a jumping or jerking feel occurs accompanied by a clunk noise.
Correction
Important: DO NOT remove the differential cover from the rear or the two sides. It is not necessary to flush the old fluid from the differential.
Drain and refill the rear differential fluid using the procedure listed below.
Draining Procedure
Raise and support the vehicle.
Clean any dirt from around the differential drain plug.
If not equipped with a differential cooler, remove the drain plug (1) and washer (2) from the differential.
If equipped with a differential cooler:
4.1. Using a bent tip screwdriver, remove the quick connect fitting retaining ring (3) from the quick connect fitting (4) and discard the retaining ring.
4.2. Remove the differential cooler inlet pipe from the differential nut.
Drain the fluid.
Filling Procedure
If not equipped with a differential cooler, install the drain plug (1) and washer (2) to the differential.
Tighten
Tighten the differential drain plug to 35 N·m (26 lb ft).
2.1. Install a new retaining ring.
2.2. Connect the differential cooler pump inlet pipe (2) to the differential. A distinct snap should be heard or felt when assembling the cooler pipe to the fitting.
2.3. To ensure the cooler line is properly installed, give the cooler pipe a gentle pull.
Clean any dirt from around the differential fill plug.
Remove the fill plug and washer from the differential.
Important: DO NOT add any limited-slip additive (friction modifier). With this new fluid (Dexron LS Gear Oil 75W-90) it is no longer required to add friction modifier. If friction modifier is added, it will cause the fluid to lose some of it's friction reducing properties as well as reducing seal life.
Fill the differential with the new DEXRON® LS gear oil, P/N 88862624 (Canadian P/N 88862625). Refer to the table listed below for lubrication specifications.
Check the fluid level to ensure it is even with the bottom of the fill plug hole to no lower than 6 mm (0.25 in) below the opening.
Install the fill plug and washer to the differential.
Tighten
Tighten the differential fill plug to 35 N·m (26 lb ft).
Important: Steps 8-13 are for vehicles equipped with the differential cooling system. For vehicles not equipped with the cooling system, proceed to step 14.
Raise the vehicle so the wheels are about a foot off the floor. Make sure the wheels can spin freely without obstruction from the hoist or any nearby items.
Start the vehicle and put the transmission in second gear. Slowly accelerate to 10 mph and hold this speed for one minute.
Turn the vehicle off .
Raise the vehicle.
Check the fluid level in the differential. Add fluid until the recommended level is reached.
Lower the vehicle.
Once the differential fluid has been changed, the vehicle must be driven in 8-10 tight figure eight maneuvers to heat the fluid and allow the fluid to be worked into the clutch plates.
Lubrication Specifications Application
Quantity
Metric
English
2004-2005 XLR (Including Export) and 2005 Corvette (Non Export)
1.72 liters
1.85 quarts
2006-2008 XLR (Including V-Series and Export) and 2006-2008 Corvette (Non Z06)(Non Export)
2.0 liters
2.11 quarts
2005 Corvette Export
1.88 liters
1.99 quarts
2006-2008 Corvette Export (Non Z06)
2.16 liters
2.28 quarts
2006-2008 Corvette Z06
2.75 liters
2.91 quarts
Parts Information
Part Number
Description
88862624 (US-1 Quart)
88862625 (Canada-1 Liter)
DEXRON® LS Gear Oil
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
F9709*
Drain & Refill Rear Axle Fluid
0.6 hr
* This is a unique labor operation number for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
2005 Chevrolet Corvette
Great Job
Condition
Cause
Correction
Draining Procedure
Drain the fluid.
Filling Procedure
Tighten
Tighten
Raise the vehicle.
Lower the vehicle.
Quantity
Metric
English
1.72 liters
1.85 quarts
2.0 liters
2.11 quarts
1.88 liters
1.99 quarts
2.16 liters
2.28 quarts
2.75 liters
2.91 quarts
Parts Information
Part Number
Description
DEXRON® LS Gear Oil
Labor Operation
Description
Labor Time
F9709*
0.6 hr
Condition
Cause
Correction
Draining Procedure
Drain the fluid.
Filling Procedure
Tighten
Tighten
Raise the vehicle.
Lower the vehicle.
Quantity
Metric
English
1.72 liters
1.85 quarts
2.0 liters
2.11 quarts
1.88 liters
1.99 quarts
2.16 liters
2.28 quarts
2.75 liters
2.91 quarts
Parts Information
Part Number
Description
DEXRON® LS Gear Oil
Labor Operation
Description
Labor Time
F9709*
0.6 hr
