C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Methanol mixture
Old Dec 10, 2009 | 11:45 AM
FastGhost's Avatar
FastGhost
Default Methanol mixture
Does anyone who uses methanol know how close -20* windshield washer/deicer is to a 50/50 water methanol mixture is?
There's a sale on this washer fluid 2/$3.00.
Thanks,
Old Dec 10, 2009 | 01:33 PM
D C's Avatar
D C
USMC (retired)
just use the yellow bottles of heet instead which is much closer to 100% methanol.
Old Dec 10, 2009 | 03:24 PM
FastGhost's Avatar
FastGhost
I'm tuned for 50/50. I have no problem getting 100% methanol.
Thanks..
Old Dec 10, 2009 | 03:38 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
im going to go ahead and say that ww fluid, is not going to be 50/50. usually the -20 stuff is 33% meth
you can find more info on ww at meth injection using google. esp on the grand national forums
-carl
Old Dec 10, 2009 | 03:39 PM
MARSC6's Avatar
MARSC6
Windshield washer fluid that doesn't cost much more then water. I wouldn't trust it.
Old Dec 10, 2009 | 08:06 PM
D C's Avatar
D C
USMC (retired)
You should just tune for straight meth. What meth system are you running?
Old Dec 10, 2009 | 08:31 PM
bosco 08's Avatar
bosco 08
i've used the "blue" windshield washer fluid for over 2 years in my daily driver a highly modded turbo Subaru [22 psi 324 whp] with zero issues. don't get caught up in that BS that you have to run high percentages of meth for it to work well, the blue ww fluid works great. Walmart usually has it on sale.
Old Dec 10, 2009 | 08:48 PM
Slvr08Z51's Avatar
Slvr08Z51
If your car is tuned for 100% meth and you listen to this guy... you will be buying a motor. Guaranteed.. Spend the whopping $7 a gallon and keep you engine alive.. I know I could not be making 700+ with less than 100% and be as safe as it is..
Old Dec 10, 2009 | 09:01 PM
Quiky One's Avatar
Quiky One
I agree with everything you say except I buy my methanol for $3.75 a gallon.
Old Dec 10, 2009 | 09:37 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
100% vp m3
Old Dec 11, 2009 | 12:07 AM
bosco 08's Avatar
bosco 08
i agree if your engine is tuned to get every last horsepower available i.e. a track car that you're making money with or a dyno queen for bragging rights you will need 100% meth. on the other hand a street car tuned as a daily driver that will see all weather and temperature conditions and still make respectable power safely the blue ww fluid is great. the blue ww fluid is also readily available, cheap to buy and no mixing.
Old Dec 11, 2009 | 12:15 AM
aTX427's Avatar
aTX427
I would not risk burning up a $20K engine to save a couple dollars running walmart wiper fluid.
Old Dec 11, 2009 | 12:59 AM
bosco 08's Avatar
bosco 08
you're not risking a damn thing if the car is tuned for the % of meth you're using. hell, if it's tuned properly you could use straight water with good results. it's true you can run more timing/boost and get higher hp from straight meth but for a street car that gets driven daily it's really not needed. you boys do what you want and good luck.
btw you can purchase the blue ww fluid at most gas stations in the midwest.
Old Dec 11, 2009 | 01:12 AM
aTX427's Avatar
aTX427
Well good luck with that.
Old Dec 11, 2009 | 02:31 AM
FastGhost's Avatar
FastGhost
I have the tune for 50/50. I want it that way to have a safe tune not to run the engine on it's edge.
My 97 was tuned for 100% methanol and ran great.
I'm just was interested in ww fluid so I don' have to mess with mixing the water and methanol.
If my tune was for 100% methanol, I wouldn't even attemp to use ww fluid.
Old Dec 11, 2009 | 05:41 AM
D C's Avatar
D C
USMC (retired)
Here's a short list of different windshield washer fluids and their perspective methanol content. You'll find that even -20 degree windshield wiper generally contains approx 30% methanol. I haven't been able to find out anything more on the topic of Ethylene Glycol. I'm sure we talked about this already. Another choice for fluid would be denatured alcohol which you can buy at Home Depot.
Brand__Temp____Methanol %____Ethylene Glycol__Isopropanol
Splash____+32______1% by weight______ 0%______ 0%_____
Splash____+22_____ 8% by weight_______ 0%______ 0%_____
Splash____-20______ 31% by weight______ 0%______ 0%_____
Splash____-25______ 34% by weight______ 0%______ 0%_____
NuGenTec +20______0%_______________ 0%______ 5%_____
NuGenTec__-0______ 0%_______________ 0%______ 30%____
Splash Di-Icer*-30___41% by volume_____ 0%______ 0%_____
Peak______+32_____1% by weight_______ 0%______ 0%_____
Peak_____ +20______20% by weight______0%______ 0%
Peak_____ -0_______ 23% by weight______ 0%______ 0%
Peak_____ -20______ 33% by weight______ 0%______ 0%
Peak_____-25______ 35% by weight______ 0%______ 0%
Mr. Clean_ +32_____ 1% by weight_______ 0%______ 0%
Mr. Clean_ +20_____ 10% by weight______ 0%______ 0%
Mr. Clean_ -30______ 36% by weight______ 3%______ 0%
Austins___ -25%____ 35% by weight______ 0%______ 0%
Austins De-Icer_N/A_ 30.9% by weight_____3%_____ 0%
Austins____+32_____ 2.8% by weight_____ 0%______ 0%
SuperTech -25______ 38% ______________0%______ 0%
Supertech -20______ 30% weight_________0%______ 0%
SuperTech +22______<8% by weight______0%______ 0%
http://www.superclean.com/pdf/Splash_Wash_4.pdf
http://www.nugentec.com/MSDS_Sheets/...luid%2020F.pdf
http://www.hardwarestore.com/media/msds/256131.pdf
http://www.peakantifreeze.com/peak_bluewash.html
http://www.mrcleanwipers.com/wash.html
http://www.pennzoil-quakerstate.com/...l7_msds_fs.htm
http://msds.walmartstores.com/search_results.asp
Old Dec 11, 2009 | 03:33 PM
FastGhost's Avatar
FastGhost
Thanks DC, this is great information for us who wondered about the percentage in these ww fluids.
I guess I'll stick to mixing my own with meth and DW....Splash -30* has the highest rate at 41% methanol. Even the -20* Peak has 33%.
To Methanol mixture
Old Dec 11, 2009 | 04:28 PM
wooden's Avatar
wooden
I run strait methanol but have ran ww fluid in other motors it works just fine its all what you tune it for. there is nothing wrong or dangerous with running ww fluid.
Old Dec 11, 2009 | 05:55 PM
Mr.Big's Avatar
Mr.Big
but you're not running VP Fuels M3 like we are... with the additives for anti oil consumption, that will make your cylinders and rings happy... there is a reason my little LS2 has been able to stay together with the power it makes for so long, a TON of preparation has gone into the right setup (for me) and part of said setup is 100% VP M3... I buy it by the 55gal drum and it comes to $6.42/gal... however run what you wish
Old Dec 11, 2009 | 06:03 PM
Quiky One's Avatar
Quiky One
Good points! I have run about 5 gallons of the M3 when I run out at the track. I have 295 1/4 mile passes on this motor and multiple hard street runs without issue! Pushing 25 psi on 91 octane. Not on an LS motor though. Completely different application.
After your post I probably will switch over to the M3 permanently. Thanks for the info.
Jason
