C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
experts needed: LS3 Safe Boost
Old Dec 31, 2009 | 12:25 PM
  #41
old motorhead's Avatar
old motorhead
Originally Posted by vetteluv10
The Ls3 motor are a new style motor that can handle certain amount of power safetly, after trying to make over 700rwhp the rods gives up, some may think it is safe until it goes into pressure, dyno Queens and searching for numbers are quite safe but that is where it stops.
I can safely say, the connecting rods will not handle over 700rwhp under heavy pressure(high RPM constantly) or constant racing. Don't ask me how I know, its a secret.
Don't keep it a secret. That's what I like about this forum. Learn from other's successes and screwups. In your case, what did it take to break the LS3?
Old Dec 31, 2009 | 04:34 PM
  #42
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
its not necessarily the motor, its bad gas causing detonation, a forged piston can take more abuse then say a cast unit in the event that some bad gas gets sprayed in
Old Dec 31, 2009 | 06:23 PM
  #43
vetteluv10's Avatar
vetteluv10
3rd Gear
Spin the first thought was the piston but after good examination we realized it was the rod that gave up, I was even told by a pro. the rod cannot take the abused.
Old Dec 31, 2009 | 11:00 PM
  #44
birk1's Avatar
birk1
St. Jude Donor '09
update / FYI
got my car tuned today...
making 9.8 lbs of boost
645 rwhp / 567 tq on 91 octane pump gas
could not do better than that as we kept getting knock and timing would be pulled because of it.
I was hoping for better, but with this **** gas we have in Oklahoma that seems to be the best I can get, which is still a nice 30- 35 HP gain in most places under the curve from 5K rpm 6700 rpm...so I guess I am "happy"
Old Dec 31, 2009 | 11:29 PM
  #45
vetteluv10's Avatar
vetteluv10
3rd Gear
Originally Posted by birk1
update / FYI
Just install a meth kit and you will be able to do better, but be carefull, because the rods are not as strong as the other parts in the motor.
Old Jan 1, 2010 | 12:07 PM
  #46
birk1's Avatar
birk1
St. Jude Donor '09
thanks...but I really dont want to add meth to the car - but prefer to keep it "simple" running off just pump gas (albiet very bad pump gas at 91 octane ) If I add meth then I could use it as protection from bad gas, but not tune for it... at least thats my preference.
I was hoping to get around 670ish with the addition of 3.5lbs of boost (9.8 -10 lbs total boost and the KB BAP turned all the way up with 65 lb injectors ) but the car just couldnt do it...
one thing to note is the number is WITH my air intake on * DP Big mouth* I believe in tuning with what the car actually with be driven with daily.
Old Jan 1, 2010 | 06:39 PM
  #47
adam205348's Avatar
adam205348
update / FYI
That is very impressive with no meth and on 91 octane. One question I am wondering is if the tune is pretty agressive or not. Basically when it is summer time and getting up to 100 degrees will you be worried about detonation or anything?
Old Jan 1, 2010 | 06:46 PM
  #48
dmaxcamss's Avatar
dmaxcamss
I would say it's about average on the power as he does have a cam. I'm at 600 rwhp with no cam, pump gas, no meth, etc. Basically blower & exhaust (headers, catless x-pipe, catback) with 10 psi. Cam gains vary, but I would think with the right cam, I could be as high as 675rwhp, maybe more. I hear that with the right blower cam, gains can be as high as 100rwhp.
Old Jan 1, 2010 | 07:06 PM
  #49
adam205348's Avatar
adam205348
True, I forgot about him having a cam.
Old Jan 1, 2010 | 09:08 PM
  #50
birk1's Avatar
birk1
St. Jude Donor '09
the tune is conservative...so summer time driving should be okay
as far as the cam goes...its NOT a blower cam, but a torque cam when I was running all motor
223 / 240 610 lift and 112 LSA....
so I guess all in all I am happy...might swap cams out one of these days but to be honest 645 is more than I can put to the pavement anyways
Old Jan 2, 2010 | 04:00 PM
  #51
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
No way at 15psi or less on a LS2/LS3. 100 rwhp just is not a realistic gain over the stock cam on these engines. Even 50 rwhp is on the high side. The stock cams are very good for FI. Decent gains are to be had when you have a MUCH better cylinder head than stock. On stockish cylinder heads most of the gains are midrange with small peak gains.
Old Jan 3, 2010 | 02:58 PM
  #52
dmaxcamss's Avatar
dmaxcamss
I don't speak from personal experience, I was just stating what I have been informed. I was always under the impression that with the right blower cam, gains are from 50-100 rwhp, with 80 being the norm. Even at 50 rwhp, I'd be a happy camper.
