C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LT's vs. Boost Loss
Old Dec 25, 2009 | 08:35 PM
Mr.Big's Avatar
Mr.Big
Originally Posted by chevpwr
Not to be a smart ***, but it was in post #1
ha haaaaaaaaaaaaaaa... I didn't see it either
Old Dec 25, 2009 | 08:43 PM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
I live in Oklahoma so I was going to have Dallas Performance tune the car after all the changes. I got a HP Tuner with the car but have not had time to play with it yet.
You're in great hands with Taylor
Old Dec 25, 2009 | 08:47 PM
chevpwr's Avatar
chevpwr
I was hoping someone would say that!
Old Dec 25, 2009 | 08:48 PM
chevpwr's Avatar
chevpwr
So... which pulley, the 3.8 or the 3.6?
Old Dec 25, 2009 | 08:49 PM
Mr.Big's Avatar
Mr.Big
ha haaaaaaaaaaaaaaaaaaaaaaaaa... goes without saying!!!
Old Dec 25, 2009 | 08:50 PM
BornSUPERCHARGED
Do you have the 6-rib or the 8-rib? The normal A&A kit is the 6-rib.
Old Dec 25, 2009 | 08:51 PM
BornSUPERCHARGED
You know what would be awesome, is if some of us guys that had Taylor work on our cars got together one day for lunch
Old Dec 25, 2009 | 08:57 PM
Mr.Big's Avatar
Mr.Big
We do it all the time, check your p.m. box...
Old Dec 25, 2009 | 09:32 PM
chevpwr's Avatar
chevpwr
Just the 6 rib kit, I could do lunch but it would have to be on a weekend, as I am 5 hours away from dallas.
Old Dec 26, 2009 | 01:25 AM
Slvr08Z51's Avatar
Slvr08Z51
Weeeeerd..
Old Dec 26, 2009 | 01:26 AM
Slvr08Z51's Avatar
Slvr08Z51
Like tomorrow after C&C!!
Old Dec 26, 2009 | 12:22 PM
Boat Racer's Avatar
Boat Racer
I have a all stock motor 2007 Z51 A6 car with a A@A SC kit (V2 SI Trim)
making 8.5-9 lbs with a 4.0 sc pulley and meth. I am wanting to put long tube headers with high flow cats and leave the factory mufflers for now, how much boost will I loose, will a 3.8 pulley get me back to the same boost lbs? Will a 3.6 be way too much for a stock bottom end? I am wanting a "safe" 560-590 whp
Thanks in advance.
I have a all stock motor 2007 F55 A6 car with a A@A SC kit (V2 SI Trim) making 10-11 lbs with a 3.8 sc pulley (no meth). The SC is one of A&A's newer kits (just installed a couple of months ago) with the new air inlet dongle. I'm thinking that the new dongle may add a little boost pressure since before the headers on a completely stock motor it made 10 psi at WOT. I was expecting somewhere in the 8 psi range with the "standard" 3.8 pulley (with no headers). Since we have 91 octane gas here, my tuner had to drop the timing to 8-9 degrees at WOT to keep it from detonating. It made 518/478 at the wheels and I was happy with that but concerned with the 10 psi boost on 91 octane gas with no meth. I talked to few people and they recommended adding the LT headers to try and drop the boost 1-2 psi and allow for more timing and more HP. I then added a set of ARH catted LT headers. As suspected that leaned out the motor, so my tuner had to add more fuel when he retuned it but the boost did not drop at all. In fact it picked up 1 psi to 11 at WOT (maybe due to the better air conditions). He was able to only add 1-2 degrees of timing (now around 11 at WOT if I remember correctly). The car only picked up 18 HP with the headers, now at 536/496.
So, to answer your question, you may not lose any boost by installing the headers but with your meth setup, you should be able to add more timing than what I have and reach your HP goals with a 3.8 pulley. I am thinking of adding the meth kit too but I'm concerned just how much power the A6 can take before it breaks.
Old Dec 26, 2009 | 12:45 PM
  #33
BornSUPERCHARGED
Some people are putting more than 700rwhp through it. 600rwhp is widely accepted.
Old Dec 26, 2009 | 12:47 PM
  #34
chevpwr's Avatar
chevpwr
That was my next question, thanks!
