Have you guys ever had any back fire issue's before? I have never seen that in an SC application.
Never seen it on the dyno or after logging it on the street to confirm spark. But I don't get to daily drive this thing nor race it so Mr.Big would have to answer. However it doesn't really surprise me in this particular case since I have it setup to spray a BUNCH of methanol. I figured that poor stock LS2 needs as much cooling as it can get to keep on going.
Probably need to back it down a touch. Still I would rather this than a cracked piston...
Hey Taylor, does Jeremy spray more meth than mine? Should I be worried that mine is going to pop the intake eventually?
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
True, I was just thinking it was more of a brittle plastic/to much boost, thing, then a back fire. Of course I'm not in the car either though.
