C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
FAST casualty
Old Dec 28, 2009 | 11:21 PM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
Scary **** for sure. Glad it was just your intake manifold
Old Dec 28, 2009 | 11:36 PM
MachineWorks's Avatar
MachineWorks
This was mostlikely from meth, just ny 2 cents.
Old Dec 28, 2009 | 11:54 PM
BornSUPERCHARGED
Any reasoning to back your logic, or just a wild guess?
Old Dec 29, 2009 | 12:12 AM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
Probably from personal experience since Billy also uses a large dose of meth in his setup
This is a very likely guess. It does happen on occasion when you start making bigger power and you are using a larger than normal amount of methanol. At the "normal" usages it's not an issue.
Old Dec 29, 2009 | 12:19 AM
BornSUPERCHARGED
So would you recommend the FAST burst panel kit?
http://www.flp-store.com/burst-panel-kit.html
$150 seems cheaper than replacing the whole intake manifold.
Actually, would you (or anyone who knows) be willing to explain what the burst panels actually do? "By installing a FAST LSX Burst Panel Kit you create a mechanical boost release system to avoid these costly problems.", so does that mean the pressure is released out of the intake manifold? How does it do that... I mean if its backfiring, then its combusting inside the manifold, so wouldn't that mean there is fuel? So if it releases the air and fuel out of the manifold, would that mean you would have fuel all over your engine? Honest question, sorry if it's stupid.
Old Dec 29, 2009 | 12:52 AM
Former Vendor
I really wouldn't be worried about it at your power level. For Mr.Big, you bet. Basically if pressure in the manifold exceeds 36 psi, the burst disc will rupture and release the pressure. Saving the intake for damage. It still requires that you remove the intake manifold to replace the burst disc/s.
Old Dec 29, 2009 | 12:56 AM
BornSUPERCHARGED
Thanks for the explanation
Time to find something else to have you install
Old Dec 29, 2009 | 04:22 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Methanol is a fuel... Fuel + Air + backfire = Explosion
Old Dec 29, 2009 | 11:06 AM
BornSUPERCHARGED
Simple enough, but would that mean that the only time this could happen is when using meth? i.e. is the reason itself the meth, or did it just compound the backfire when it occurred because the meth was there and ignited? Is this why people say to use 51/49 water to meth mixed instead of 100% meth, something about its not flammable? As always, correct me if I'm wrong, just trying to learn.
Old Dec 29, 2009 | 11:14 AM
Former Vendor
Probably just compounded the backfire more than likely. The idea behind the 50/50 mix is mainly from people who are concerned about a fire if the tank was ruptured.
Old Dec 29, 2009 | 11:17 AM
BornSUPERCHARGED
Learning something new every day.
Old Dec 29, 2009 | 11:45 AM
greekc6's Avatar
greekc6
hey sam you back home yet. going to that car meet tonight in jersey
Old Dec 29, 2009 | 01:54 PM
  #33
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
and call it done.
Old Dec 29, 2009 | 01:56 PM
  #34
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
One more reason to get your fire extinguisher kit.
Old Dec 29, 2009 | 07:46 PM
  #35
drivinfast's Avatar
drivinfast
Originally Posted by Mr.Big
guys I give you all my word, I haven't used the N2O in over 2.5 years, when we got to ~700rw on boost, I knew the extra shock from the 120rw the N2O provided, would probably be too much for the stock bottom end to handle... this was just from an off throttle boost run, and not uncommon, ask any of the "higher" hp guys that race... usually it doesn't blow the intake apart though most of the time it's mild enough to barely hear... this time I thought it blew my dash apart... scared the **** outta me...
now when we finally forge the bottom end, the N2O will be used when needed!!!
I was kidding around on the NOS Jeremy, I wouldn't expect your stock engine (im still amazed anyway as to how much it has taken) to handle the extra shock.
you still coming houston way in a bit?
Old Dec 29, 2009 | 08:48 PM
  #36
Mr.Big's Avatar
Mr.Big
got here last night!!!
Old Dec 29, 2009 | 10:26 PM
  #37
PowerLabs's Avatar
PowerLabs
Nah, I'm spending New Years in Sydney and coming back on the 5th I think.
To FAST casualty
Old Dec 30, 2009 | 09:28 AM
  #38
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Have you guys ever had any back fire issue's before? I have never seen that in an SC application.
Old Dec 30, 2009 | 09:43 AM
  #39
Z06wanted's Avatar
Z06wanted
very interesting
Old Dec 30, 2009 | 10:07 AM
  #40
Finster07's Avatar
Finster07
Good info...
I am going to install a s/c at low boost soon. After looking at the pictures here, I wondered if using my 90mm ported FAST would be wise or not. Given all the info I read here, I think I will be OK to use my FAST with a s/c at low boost.
