C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Any hp difference ?
Old Jan 23, 2010 | 12:22 PM
DSILVERC6's Avatar
DSILVERC6
Default Any hp difference ?
I had my 06 a6 maggie car on the dyno & tuner had the pulls done on third gear is there any difference in hp if the pulls would of been done on third again its an a6 car thanks in advance
Old Jan 25, 2010 | 08:14 AM
DSILVERC6's Avatar
DSILVERC6
Bump
Old Jan 25, 2010 | 05:56 PM
Bushong572's Avatar
Bushong572
It should have been dyno'd in 4th (1 to 1). I would think the results would definitely be skewed (I don't know how much, though). I would have them run it again.
Old Jan 25, 2010 | 10:46 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
I have seen the HP numbers are lower if dynoed in a gear that is less than 1 to 1. Your car should show higher if you redynoed in 4th gear. The standard on chassis dynos is to dyno in the gear closest to 1 to 1 which is 4th on the 6 speed autos.
Old Jan 26, 2010 | 06:19 PM
tlove32's Avatar
tlove32
IIRC - the A6 does not have a 1:1 ratio in any of the trans gears. But the run should have been made in 4th since it's the closes ratio at 1.15:1
Old Jan 26, 2010 | 06:51 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
No difference whatsoever on a load bearing ("brake") dyno.
On an inertia dyno dynoing in a lower gear will do the same as dynoing a car with a higher final ratio; it will show slightly lower power numbers.
To Any hp difference ?
