C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Dear god, please help!
Old Feb 27, 2010 | 02:46 AM
theshop001's Avatar
theshop001
Default Dear god, please help!
Ok, just got car back from tunner and wanted to throw up. Not the tuners fault though. 05 A&A SC, cam, AR headers made 606 to rear in december and took it back today for a check up tune and started out at 500. Finally got up to 570, but that still sucks. 9 degrees warmer with 10 less humidity. Only 3 changes were made. Went to a 335 tire, hyperlube octane booster, and swapped the american racing cats for the american racing cat delete. Thats it! Also, as a side question, only able to get 18 degrees of timing and using a 3.8 pulley its making 10lbs of boost. So..... Please help me get back into the sixses!!!!
Old Feb 27, 2010 | 06:43 AM
setxws6's Avatar
setxws6
Do a compression test. Check the plugs for fouling.
Old Feb 27, 2010 | 09:42 AM
Mr.Big's Avatar
Mr.Big
WOW!!! 18* is a TON of timing!!! what's your A/F? That amount of timing is waaaaaaay too much for the setup you have listed...
Old Feb 27, 2010 | 10:28 AM
tjwong's Avatar
tjwong
I bet that its running on the low octane spark table with a lot less timing......or worse case scenario, the tuner made both high and low octane spark tables the same with too much timing and something happened to the engine
Old Feb 27, 2010 | 10:52 AM
theshop001's Avatar
theshop001
will do a compression check on Monday and replace the plugs. when I pulled the plugs yesterday, they were rust colored and i assumed it was from the otane booster. the tuner siad wants more timing and wants to try cooler plugs ( currently ngk tr6) to achieve that. i like my tuner but he too seems baffled. he also told me to do a compression check before installing ngk br8. any insite would help. not sure on a/f but will ask.
Old Feb 27, 2010 | 11:42 AM
07MontRedcp's Avatar
07MontRedcp
Mine has about 13* w/meth and 91 octane @ 9.5 psi.
BJK
Old Feb 27, 2010 | 12:07 PM
MachineWorks's Avatar
MachineWorks
Your tuners shouldn't learn how to tune FI cars on your dime.
Old Feb 27, 2010 | 02:36 PM
BigMay60's Avatar
BigMay60
18 Degrees.....?? There is something wrong there. That is by no means a safe tune.
Old Feb 27, 2010 | 05:36 PM
theshop001's Avatar
theshop001
Default compression
did compression all but 7 were at 210, 7 was at 180. did a wet test and all went to 210.
Old Feb 27, 2010 | 05:45 PM
theshop001's Avatar
theshop001
boost is 10- 10.5. any suggestions on cam size? also, wondering if my cam is not timed right? 234/242 on 115lsa .596/.605 sound good?
Old Feb 27, 2010 | 06:52 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
18* with 10psi, and proper fuel is more than fine.. No big deal at all. Provided the tune is right.
Old Feb 27, 2010 | 09:17 PM
theshop001's Avatar
theshop001
any clue why i dropped 36 rwhp after deleting the cats and adding octane.
Old Feb 27, 2010 | 09:18 PM
theshop001's Avatar
theshop001
and how do i add a dang picture under my name? thanks
Old Feb 27, 2010 | 09:27 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Did you disable the rear O2's in the tune? Or al least use O2 sims?
Old Feb 27, 2010 | 11:11 PM
mattsc's Avatar
mattsc
I run 17 degrees with 75% meth with 10.5 afr at wot and very low AIT even in Florida heat...610 WHP no cam no heads bone stock just headers.with no problems (yet)..
added: This is a stock LS2
Old Feb 27, 2010 | 11:12 PM
mattsc's Avatar
mattsc
Oh,3.4 pully 12 psi max on a stock LS2
Old Feb 28, 2010 | 12:51 AM
BartonekDragRacing's Avatar
BartonekDragRacing
hey man, your car, from the profile pic looks bad ***... got more pics?
To Dear god, please help!
Old Feb 28, 2010 | 07:44 AM
Mr.Big's Avatar
Mr.Big
I run 17 degrees with 75% meth, no problems (yet)..
correct, with METHANOL... NOT in this guys setup. I'm only at 16* at 800+rwhp with a ton of methanol. No way his tune should have 18*!!! ouch...
Old Feb 28, 2010 | 08:26 AM
filmjay's Avatar
filmjay
St. Jude Donor '10
I don't know who your "local" tuner is, but you're in Texas...a interstate blast away from a good amount of the recognized top, reputable Vette tuners in the entire US. I could name 3-4 off the top of my head that are a mornings' drive from you.
Pick one, make an appointment, and head on out. Worst case, you might have to spend the night. But it sounds like it would still be cheaper than having your local guy learn troubleshooting at your expense.
Best of luck!
Old Feb 28, 2010 | 09:25 AM
excessive81's Avatar
excessive81
.........find someone that knows what they are doing...FAST!!
