C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost gauge question
Old Mar 8, 2010 | 10:06 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Originally Posted by Robls6
Didn't try that. It does read 17 at idle and go down when I give it gas. Is it really possible to have 17 inches of vacuum at idle though? That just seemed a little off to me. I assume I probably wont see mush boost without a load on the engine. Maybe I'll button it up and take it for a little road test and see what it reads.
17 makes perfect sense because the throttle plate is closed but the motor is running (the motor is sucking air, since it aint getting any from the intake its making vacuum) i would test drive quickly before doing any more work
Old Mar 8, 2010 | 10:10 AM
Robls6's Avatar
Robls6
Thanks. I think I will do that.
Old Mar 8, 2010 | 10:41 AM
csun213's Avatar
csun213
Sounds like you are reading vacuum and not boost. Do you have memory function on your gauge? Is so, just push the memory function and you would see Hi and Low both being 0 since the gauge does not store vacuum reading, only boost.
