C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS question
Old Mar 25, 2010 | 08:57 AM
KLRBEE2's Avatar
KLRBEE2
Default ECS question
Greetings,
As I understand it, ECS has authorized dealers/installers for the kits. My question is: If I purchase, say a SC600 w/meth kit, that Doug would have tunned at around 650-700RWHP, and have it installed in the authorized place, would they be able to tune with the same results?
Thanx!
Old Mar 25, 2010 | 12:00 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Not every identical setup will produce identical numbers. There are lots of variables that will affect the final output.
I've seen guys with my same ECS/LS3 setup range from 50hp less to 50hp more.
Old Mar 25, 2010 | 12:29 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by LeMansta'
Greetings,
Thanx!
I often send tunes to our install centers, along with giving any info necessary to duplicate what we produce here regularly. I'm sure we can help you achieve the same!
Old Mar 25, 2010 | 07:57 PM
KLRBEE2's Avatar
KLRBEE2
Thanx for the response Doug! I know you guys are putting down some mad power and I don't want to be shorted out with someone less skilled or familiar with your systems. I would be in GA when I do this, and it will be a while, since I'm in Korea, but I'll make up my mind by then wether to take the trip or do it in GA...it would be a nice drive there and brake in on the way back. Can't wait :{
Old Mar 25, 2010 | 09:31 PM
Timinva's Avatar
Timinva
I would recommend taking the drive up to ECS;. While I am sure there are many good tuners out there, Doug is one of the best. I researched this a lot before making my choice. Could not find any negative info about Chris, Doug or Ecs. Tim
Old Mar 25, 2010 | 11:31 PM
KLRBEE2's Avatar
KLRBEE2
I appreciate the input, as I see you have a preety badass car yourself. I think this is what I will do...when back in the states :{
Old Mar 26, 2010 | 08:58 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Thanks in advance then!
Old Mar 26, 2010 | 08:05 PM
gibear2k5's Avatar
gibear2k5
Doug/Chris - just want to make sure we are still on for Wed evening?
Scott
To ECS question
