C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Which meth controller? Why?
Old Apr 15, 2010 | 11:46 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Default Which meth controller? Why?
I just can't decide which controller would be best suited for me.
The Labonte controller looks and sounds pretty slick on paper. Not to mention, some built-in safety features. Plus the "self-tuning" controller would be helpful 'til I could get it properly tuned. Might be a while before I can get it to a preferred tuner and I just don't know enough about it yet to want to attempt it on my own.
I like the idea of the progressive Alky controller. But as a dual-duty DD/weekend track warrior (drag and road), AND frequently traveling long distances through what will soon be sweltering Southern heat...I think I'd rather have a bit more adjustability for varying conditions.
And the Snow...awesome system, but jeebus it's expensive...especially adding it all up with the additional safety features (sold separately)
What else should I be looking for in a S/C meth setup? It seems that all the systems are pretty much the same other than the controllers.
Thanks for any info.
Old Apr 16, 2010 | 12:02 AM
396375's Avatar
396375
St. Jude Donor '08-'09
Alky Control.Most popular and used on a lot 800+HP guys who know their stuff.Great back up too.Doen't try out trick yourself.They just work.
This is the same kit.
http://forums.corvetteforum.com/c6-f...th-at-ecs.html
Good luck.
Old Apr 16, 2010 | 01:35 AM
filmjay's Avatar
filmjay
St. Jude Donor '10
Yeah....I've been eye-balling that thread pretty closely.
Old Apr 16, 2010 | 08:42 AM
vertC6's Avatar
vertC6
The Alky control can't do what these can,
http://www.labontemotorsports.com/st...onSystems.html
Old Apr 16, 2010 | 09:31 AM
396375's Avatar
396375
How do you like the Labonte kit?
Old Apr 16, 2010 | 09:38 AM
vertC6's Avatar
vertC6
I don't have one yet both the feature controls on this unit are amazing. Includes a lot of fail safe options too.
Old Apr 16, 2010 | 11:45 AM
Quiky One's Avatar
Quiky One
Go with ECS's/alkycontrol setup...the way to go! Reliable, progressive, and easy to tune.
Jason
Old Apr 16, 2010 | 02:35 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
The Stage 3 Labonte setup is exactly what I'm wanting and have been looking at for the last month. Seems to be the most versatile controller of the "big 3 meth kits"
Just can't find much in the way of experience with it though. I do LOVE the fact that it would kill 2 A-pillar gauges in one unit.
The Alky system is the most widely used, but no safety features included...they're extra. And it's just a progressive, ramp-style controller.
Same for Snow...the "SafeInjection" controller is an additional $180. But it does look like the best fail-safe available.
And I've read enough horror stories across the various forums to know that I don't want quick disconnects on any high pressure line.
I also would rather use the WW tank to keep the low level warning on the DIC...or at least a warning on the controller if the particular kit comes with its' own reservoir.
I also looked at the new all-inclusive cubby tank from ETMC...but my storage compartments are occupied (BaP in the right, Tools I have to carry for work in the left) so that's definitely out.
I'd like to know a little more of WHY someone would recommend a particular kit. "This guy/team uses it" isn't really valid. "Guys" and "teams" use all of them.
Guess I need to do one of those big comparative feature checklists.
Old Apr 16, 2010 | 07:56 PM
Mr.Big's Avatar
Mr.Big
Alky Control... Because it's a time tested and proven system... You do not need all the "bells and whistles" features, you DO NOT want to tune with the methanol system, you want it as "dumb" as possible, all of your air fuel tuning should be done through the "ECM" which is FAR superior to the meth systems "CM"... Period, plain and simple, no methanol control module can hold a candle to the data and sampling ability of the ECM in your C6.
Old Apr 16, 2010 | 09:28 PM
396375's Avatar
396375
Kiss :d
Old Apr 16, 2010 | 09:51 PM
Quiky One's Avatar
Quiky One
Exactly. Plus it comes with brass or stainless steel fittings (no plastic push in connectors), all the wiring is soldered, and the pump is 100% methanol compatible.
Jason
Old Apr 17, 2010 | 12:22 AM
drivinfast's Avatar
drivinfast
If you go ECS or similar, 2 suggestions. get the mod that brings the bottom of the pump from hanging below the rocker panel, anyone can make a mistake and bust it jacking the car up or something, and get the SS fittings
Dallas Performance can take care of you on all counts, especially the "safe" tune mentioned by MrBig
Old Apr 26, 2010 | 11:11 PM
AVB's Avatar
AVB
If you haven't already, give Julio a call and ask him yourself why all those bells and whistles aren't in his kit.... If you want to make a good decision, that's as educated as it gets.
Old Apr 27, 2010 | 08:59 AM
excessive81's Avatar
excessive81
i looked at them all agian last few days. i needed something to control my meth and fuel pump so i went with the cooling mist controller and flow sensor yesterday...
link..
http://www.coolingmist.com/detailmain.aspx?pid=cmgs
cooling mist 250 psi pump
cooling mist solenoid (300 psi) instead of check valve
set up like this:
then i sourcing fittings and lines so it will loook the way i want
1st call this a.m. is to dallas performance for thier line kit
so why? well the gauge option is nice. most controllers are hideaway units with led light telling you they working. this setup has flow sensor and led bar graph showing what you are flowing and when. also incorporates a boost gauge so can loose my dedicated boost gauge and keep my dual pod pillar mounting. mutilple failsafe opions. and ability to turn on or off other items like fuel pump ect.
Old Apr 27, 2010 | 10:04 AM
backchannel's Avatar
backchannel
If the meth system uses injector duty cycle to control flow, why isn't that better than boost sensing flow control?
Old Apr 27, 2010 | 10:38 AM
user_name's Avatar
user_name
These meth injection systems are not super complicated, and there is no reason to make it that way. It's a pump, line, filter, nozzle, and map sensor. Just get quality parts. I've been happy with my Alky Control kit. Julio provided great service as well.
Old Apr 27, 2010 | 11:12 AM
TTZ06VETTE's Avatar
TTZ06VETTE
Keep it simple and have a responsive resource for questions during install and tuning. Julio at Alky Control provides both of these. I looked at all of the systems and bells and whistles out there including trunk locations for storage, failsafes, etc. In the end locating the storage reservoir as close to the injectors(ww bottle) as possible for instant response to the injectors, and utilizing the car's ECU through the IAT sensor as failsafe were the simplest. By adjusting the existing IAT timing tables and/or low octane timing tables(automatic default if system senses knock) you can even have a redundant failsafe. The Alky Control system also has (3) tuning parameters for initial spray, curve, and ramp. What more do you need?
To Which meth controller? Why?
Old Apr 27, 2010 | 12:58 PM
BADZ's Avatar
BADZ
I'm running the Snow kit and it's a very simple install and no extra safety add ons. The pump is located inside the front left fender.
My car is tuned only by the "ECM" and the meth is just an extra bonus..
Old Apr 27, 2010 | 02:24 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
AIS HANDS DOWN!!!!
Plus they have a new tank that fits in the compartment in the back driver side. PM Me if interested.
Old Apr 27, 2010 | 02:37 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
ECS Alky control kit. Why? Because we consistently make the most power with it and I have worked with just about all of them. Plus I do not care for the plastic hoses and fittings that come with other kits.
