[QUOTE=DOUG @ ECS;1573895917]ECS Alky control kit. Why? Because we consistently make the most power with it and I have worked with just about all of them. Plus I do not care for the plastic hoses and fittings that come with other kits.
Aquamist uses SS fittings. Why wouldn't you prefer the ecm to control vs a boost sensor?
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Because I often eliminate the MAF sensor, I do not care to tap into factory harness' which some require, we would run the MAF out way to often anyway, and I'm only concerned with it working under boosted conditions. Simple and effective, but if you prefer another type, great! Just relaying my experiences with different meth kits.
One issue to be seen is if following idc and reducing it for added meth, then meth flow will also reduce and it may become chasing each other to get it right.
