C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Which Wideband Gauge?
Old May 4, 2010 | 02:41 PM
mhoglund's Avatar
mhoglund
Default Which Wideband Gauge?
I'm thinking about installing gauges in my car, one of them being a wideband. Which one would work best?
Old May 4, 2010 | 03:04 PM
Jeremy@HOB's Avatar
0Jeremy@HOB
Former Vendor
Innovate LC-1 or AEM are great, affordable units. I carry both. The AEM runs $199 and the LC-1 with G2 gauge runs $235.
Old May 4, 2010 | 04:38 PM
07MontRedcp's Avatar
07MontRedcp
The AEM UEGO has a switch that allows you to display in either AFR or Lambda. Very helpful if you get into doing your own tuning.
BJK
Old May 4, 2010 | 05:01 PM
mhoglund's Avatar
mhoglund
I want to go with analog gauges. Wideband, fuel pressure, and mechanical boost. I want to get something as close to stock appearence as I can. How would you set up the data logging feature on the AEM product? Do you need a connector?
Old May 4, 2010 | 05:15 PM
07MontRedcp
http://thetuningschool.com/
Look under the Free Downloads section.
BJK
Old May 4, 2010 | 05:32 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
NGK AFX is the best thing going right now. Especially since it now comes with hte NTK sensor.
The data logging "feature" on the AEM is nothing more than an output that you would wire into a serial (DB9) connector, plug into your laptop and open hyperterm. It spews the AFRs into a log with the timestamp for each sample.
IMO the Autometer Pro Comp gauges match the dash the best. You're not going to find an analog WB gauge though. I have the AEM and it has done well. I keep it in the glovebox and I just open the glovebox when I will be doing spirited driving. I also log a ton of data into HP Tuners so I see my AFR and boost there.
Old May 4, 2010 | 05:36 PM
07MontRedcp
Bill;
Will the NTK sensor work with the AEM?
BJK
Old May 4, 2010 | 06:12 PM
mhoglund's Avatar
mhoglund
Innovate currently doesn't make a fuel matching fuel pressure gauge, however the company that makes their products for them does make a matching fuel pressure gauge. The only difference is it won't say innovate, and it matches perfectly.
Old May 5, 2010 | 12:23 PM
5 Liter Eater
St. Jude Donor '11
I don't believe so.
Originally Posted by 07MontRedcp
Bill;
BJK
To Which Wideband Gauge?
