C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Most complete NOS kit?
Old May 9, 2010 | 12:24 AM
c6 batmobile's Avatar
c6 batmobile
Default Most complete NOS kit?
Im looking at getting a NOS kit. I want to know what kits others have had experience with and what kits come with EVERYTHING I need. I dont wanna be looking around for parts and other crap to complete it. I want to buy something and then install it period.
Thanks for your feedback and input.
Old May 9, 2010 | 03:11 AM
venomws7's Avatar
venomws7
Check Nitrous Outlet IMO the best in the nitrous world..
Old May 9, 2010 | 11:06 AM
GIO-305's Avatar
GIO-305
Well let me ask you what are you realy asking?
NOS is a brand of nitrous system. Do you want to know what will be your best nitrous system from NOS?
Or what brand of nitrous to go with?
The most popular systems for the LS world is. Nitrous Outlet & Harris Speed Works
http://www.nitrousoutlet.com/
http://www.harrisspeedworks.com/home.php
I recommened for you to call them to see what will be best for your setup and budget. And they also sell complete systems with all the extras you will need.
And of course we will help you out with any ? you have when you have a idea with what you want to go with.
I went with Nitrous Outlet system with Harris Speed Works nitrous controllers
Old May 9, 2010 | 12:14 PM
c6speedjon's Avatar
c6speedjon
I just think he's asking what I wanted to know when I first was looking into doing nitrous. And since we are here to help him out, I will.
First you will need to decide if you want to go with a wet kit or a dry kit.... Things you will need are a nitrous kit, whether it be nos, nitrous outlet, TNT, dynotunenitrous, nitrous express, ect... You can go with a plate system, which I did from dynotunenitrous. They seem to be cheapest on all parts. You can buy packages from any of these sites that will give u a purge, heater, blowdown tube, ect. That might be the cheapest way to do it. But along with just the kit and a plate system (which Ive been told hits harder and spreads more evenly) you will need a purge, a blowndown tube (most tracks require this as a safety item), a bottle heater with transducer (that regulates the bottle pressure to keep it at optimal pressure for spraying it), a remote bottle opener if u don't have accesable access to just do it yourself manually (all depends on where you mount your bottle, then TPS Voltage Sensing Full Throttle Activation Switch (which you don't NEED because you can mount a wot micro switch below the pedal, but I don't trust those brackets, they easily bend), you will also need a nitrous pressure gauge, and a fuel pressure gauge (both electric, you can get those from autometer or nitrous outlet, dynotunenitrous, ect), a switch panel for arming the kit (nitrousoutlets is the nicest it fits in your ashtray and is consealed) and a pillar pod for the gauges to go in.
As far as electronics go for the system are an msd windowswitch (go with the digital), and then you'll want a nitrous controller Harris speed works sells one called the micro edge, lingenfelter has a timing retard function and a 2 step launch controller. I hope this helped
Old May 9, 2010 | 01:26 PM
RudyDavis1972's Avatar
RudyDavis1972
Cruising
Wet Nitrous Outlet kit
Old May 9, 2010 | 11:52 PM
c6 batmobile
Ive already done the research between wet and dry and it seems dry is the way to go as far as power is concerned. And yes C6speedJon is right by NOS I just mean nitrous. I know that its a brand I just use it as a general abbreviation I dont know if its correct or not.
I want a kit that has all of those parts in it already if that is out there somewhere. There are a ton of working parts to this and Im not sure I have a good enough working knowledge of it to put it all together alone which is why I want a solid kit with all the parts if it even exist.
A plate system sounds alright as well but I was looking at another members system and it seems that he installed his even further down the intake which he said prevented back fires. I dont think Im going to run a big enough shot to have a huge concern here but Im curious. Thanks again for you help.
Old May 27, 2010 | 11:02 PM
c6 batmobile
Any other suggestions guys? I still havent found a kit with the blow down tube and purge already in it. Im looking at the zex kit because it comes with the window switch and other electronics. It still needs the bottle warmer, blow down, purge and gauge but other than that it seems pretty complete. Some more input would be appreciated.
Old May 28, 2010 | 07:28 AM
MPM IV's Avatar
MPM IV
Call Nitrous Outlet and tell them what you want. Excellent customer service.
Old May 31, 2010 | 07:43 PM
c6 batmobile
I can confirm this. Ive been in email contact with them and HSW and they are both excellent thus far. Pretty close to pulling the trigger on the one I want. Thanks for all the input.
To Most complete NOS kit?
