Vortech Rear seal part number???
I tried doing a seach to see if I could just find the part number for the rear seal on a vortech T-trim...I called Vortech but they would only want me to ship the blower to them meanwhile its a quick change so ive heard......Any help and id be very thankful guys
1 Post
Make sure part is made in US with CR stamp!
Mike
It's a CR 9725... Chicago Raw Hide bought by SKF years ago. Stay away from anything under ~$12 because it's a cheap knock off. It's 25-40-7 (ID, OD and width in mm). Knocking it out, don't worry about damage, but putting it back in you have to be careful how you start it.
Mike
Mike
Is this the same number for the YSI?
1 Post
I know input shaft size is the same (25 mm) as with bearings, but YSi has angular contact versus deep groove bearings. Seal will fit or its same size... If you want I can dig up teflon version part # later, which is better suited to higher RPM (same size). Sorry I can't give you a 100% answer because I did not write down part # when I ripped one apart.
Mike
Mike
