C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Service charging system
Old Jul 5, 2010 | 11:16 PM
Captain Z's Avatar
Captain Z
Default Service charging system
Service charging system notice has been coming up intermittently lately. What troubleshooting steps can I take regarding alternater, starter, etc.
Thanks.
JD
Old Jul 6, 2010 | 12:13 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Thanks.
JD
its weird i had the same problem, how many miles have you had your sc on? if you have high mileage and a lot of sc miles the added tension from the sc could have worn out your alternator
one theory ive heard is that the extra current draw from upgraded fuel pumps + your cooling fans draws soo much current that it sets off the alarm (does the warning come on when the car is hot only?)
you could be having belt slip if the warning is coming on during WOT runs only
if it makes you feel better i was getting this a lot, then left the car alone for 2 weeks while on vacation and ever since never saw it again
Old Jul 6, 2010 | 12:26 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
It is often a battery starting to fail. Enough to start the car fine, but it takes to long for the voltage to reach it's proper level.
Old Jul 6, 2010 | 01:02 PM
SinisterC6's Avatar
SinisterC6
Speedy
when it was happening to me i saw my voltage skipping around, what could that mean?
Old Jul 6, 2010 | 01:29 PM
wishmaster's Avatar
wishmaster
I have the same problem just now i am about installing the 270amps alternator and TCI started !! will let you as soon as results on them
Old Jul 6, 2010 | 11:11 PM
White_Lightning's Avatar
White_Lightning
Do you have an underdrive pully? I have seen on several 08+ coupes and z0s..the under drive pully triggers it.
Old Jul 6, 2010 | 11:13 PM
SpinMonster's Avatar
SpinMonster
Mine was doing this and I shot contact cleaner all over the inside of the alt and the voltage shot right up. It was fine for 2 more months and came back last night.
A rebuilt stock built for 140 amps is available from Gene Culley. I will go that route after I check the connections at the starter and change the spark plugs. The battery is a new red top.
the voltage shooting right up when I tried the contact cleaner doesnt look good for the other possibilities.
Old Jul 6, 2010 | 11:39 PM
tpereira's Avatar
tpereira
Add me to the Service Charging System club as well. How much for the 140 amp alternator ?
Old Jul 7, 2010 | 12:18 PM
DOUG @ ECS's Avatar
DOUG @ ECS
It's light in the loafers?
It can also be loose/dirty battery connections.
Old Jul 7, 2010 | 12:29 PM
SinisterC6's Avatar
SinisterC6
Speedy
hmm always a possibility, its weird i was having a slow leak in one of my new tires, this service charging system issue, leave the car sitting for 2 weeks while on vacation come back and everything fixed its self, its almost like the car was afraid i was abandoning it so it cleaned up its act while i was gone - good car
Old Jul 7, 2010 | 12:33 PM
DOUG @ ECS's Avatar
DOUG @ ECS
I'm going to have to try that with my wife!
I hope it stays that way for you.
Old Jul 7, 2010 | 12:35 PM
SinisterC6's Avatar
SinisterC6
Speedy
im one laser alignment from perfection
Old Jul 8, 2010 | 01:13 PM
Captain Z's Avatar
Captain Z
No supercharger just heads/cam with all bolt-ons.
Thanks!
Old Jul 8, 2010 | 05:27 PM
csun213's Avatar
csun213
Are you getting the service message when moving or just at idle?
I have heard from other guys that if you are getting the service message only at idle then it might be that the battery is going bad.
Old Jul 8, 2010 | 09:42 PM
Mike@NorrisMotorsports's Avatar
0Mike@NorrisMotorsports
Former Vendor
St. Jude Donor '11
What we used to find the problem to be when I worked at the dealership of the C5's and today my buddys working on the C6's is aftermarket spark plugs.
As odd as this sounds, and I do not have any tech data, we would remove the aftermarkets, both back then and today, and install a set of stock plugs and pretty much all cases no more issues. It had something to do with how the AC Delcos suppress external noise that can get to the alternator and give a false reading though it is charging fine.
Downside, you would not want to run stock plugs in a SC'd car. Upside, if this is actually your issue, then when the message comes up you can tough the reset button and the message goes away. Good thing, at least I have noticed is that there is maybe 1-3% of Vettes that can have this issue.
Hope this helps.
Mike Norris
Old Jul 8, 2010 | 10:43 PM
knkali's Avatar
knkali
I had this intermittently at idle with the Volts meter showing large swings in voltage levels. I had a tune, headers, FAST, TB, CAI, TR6 plugs.
Tried new alt, tried HO alt(from Rev Extreme--what a POS !)
New battery, raised the idle too. Nothing worked.
Went back to complete stock with a Tech 2 re flash of my entire computer system and all the aforementioned problems are gone. What did the trick? Since the only thing I did not change were the plugs before going back to stock could mean it was the TR6 plugs all along. However, some on this board have the problem with stock plugs so go figure. Maybe tune related in some weird computer glitch sort of way.
Old Jul 9, 2010 | 09:01 AM
Big Turkey's Avatar
Big Turkey
Hope this helps.
Mike Norris
I have experienced 2 vettes that did this as well. One was fairly new, the other 2 years old. They were not S/C'd, only H/C/I cars. Switched to a stock plug and sure enough it fixed it.
Old Jul 11, 2010 | 11:00 PM
Captain Z's Avatar
Captain Z
Hope this helps.
Mike Norris
Thanks, Mike!! Just had colder spark plugs installed with my new nitrous system and didn't have this message prior to this. Had my battery, alternator, and starter all checked at Autozone and everything checked out fine.
This is valuable info...thanks again!!
JD
Old Jul 12, 2010 | 08:04 PM
excessive81's Avatar
excessive81
i got same issue have had it for awhile and replaced battery and alt.... i suspect that there is something like a resistor in the wire coming from the alt that goes bad and then it wont charge past 13.5 volts. i have a new one on the way so we shall see.... but the high out put alt is a joke.....
oh and i have $50 a piece jl audio battery connections so cross that off too
To Service charging system
