C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Getting my E-Force installed
Old Aug 17, 2010 | 07:48 AM
zer0t's Avatar
zer0t
St. Jude Donor '08-'10
Default Getting my E-Force installed
Gave the deposit to the good folks at ECS for an e-force installation. Should be going down in two weeks (I wish it was going today). Since my car is an auto I am hoping to get a nice tune in sport mode to get a more positive feel from the shifting. It is really sloppy.
Old Aug 17, 2010 | 08:33 AM
j_digi454's Avatar
j_digi454
Let us know how it goes.
Old Aug 17, 2010 | 10:13 AM
SGT's Avatar
SGT
Way to go, you'll love it.........
Old Aug 17, 2010 | 07:34 PM
zer0t's Avatar
zer0t
Thanks, I've tortured myself on blower v turbo and then I decided to go blower because they only kit is TTiX and as you know it is a 14k plus install. Then I saw the e-force early this year and started to think top mounted will be cool for an install and forget type car. Then it finally came out.
I chatted with the ECS guys for about three minutes before I pulled out my credit card for the deposit. However, I have done a bit of reading. I plan on taking the car for a good run before hand to remember the before feeling.
Old Aug 17, 2010 | 10:55 PM
10mikeymike's Avatar
10mikeymike
Good luck. I'm sure 2 weeks will seem like a long time. My car is in the shop now getting one installed. I'm getting new heads, cam, headers and Z06 fuel pump while it's there. I'm also having the oil pan gasket replaced as it was beginning to develop a slight leak. Nothing on the floor, but I didn't want to spend all that money on the car and have it leaking oil. Below is a link with some photos of the progress so far. It's best to start with the last one and work backwards. I have an A6 as well. I'm getting a trans. tune as part of the package. I'll let you know what I think when I get it back
http://s540.photobucket.com/albums/g...ock%20Install/
Old Aug 18, 2010 | 06:11 AM
Vetter 1's Avatar
Vetter 1
Nice appearing piece of art. Good luck with the new mod. ECS will take good care of you and send you to the races.
Old Aug 18, 2010 | 07:25 AM
rovers2000's Avatar
rovers2000
Old Aug 18, 2010 | 09:31 PM
zer0t's Avatar
zer0t
Looks good, when do you get it back? What cam, etc?
Old Aug 18, 2010 | 09:52 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Old Aug 18, 2010 | 10:24 PM
10mikeymike
My car is an A6 with an LS2 so I opted to go with L92/LS3 heads to avoid the wait for the LS2 E-Force to come out. I'm having a Livernois Stage 2C cam installed (224/236 .612/.612 -118 LSA). It's also getting Kooks long tubes and a Z06 fuel pump. Using the Z06 pump will produce the same results as the higher output set up from Edelbrock. Once done and on the dyno a determination will be made as to which pulley produces the best results. I expect to have it back early next week.
Old Aug 19, 2010 | 05:00 AM
zer0t's Avatar
zer0t
Please drop results/impressions in this thread. I was discussing a cam with ECS and haven't made a determination. I am leaning towards doing it for that bit of extra grunt. I haven't done exhaust because, like yours, it is a convertible and I am trying to hold the noise down. So I hope you get it back soon so we can read your what thoughts related to that.
Old Aug 20, 2010 | 12:26 PM
Telepierre's Avatar
Telepierre
Welcome to the E-Force club and I challenge you to keep those tires on the asphalt...;-)
Old Aug 20, 2010 | 03:16 PM
bonecrrusher's Avatar
bonecrrusher
What kit did you order - competition kit?
Everything for the LS3 kit bolt onto your LS2?
I am looking at a LS3 competition kit - since its cheaper and the doesnt have the fuel rail covers...
I have an 05 C6 - GMPP CNC ported L92/LS3 heads - LS7 manifolds....
How about the moved map sensor?
Old Aug 20, 2010 | 04:17 PM
Motorhead-47's Avatar
Motorhead-47
I think you also give up the pulley, the belt, the fuel injectors and the can'd tune/r in the competition kit along with the fuel rail covers.
Old Aug 20, 2010 | 04:42 PM
bonecrrusher
Talked to the Edelbrock reps on the Power Tour - I can order the belt and pulley seperate.
I have many local tuners, and well injectors arent that hard to figure out...
Old Aug 20, 2010 | 04:44 PM
Motorhead-47
What kind of savings do you get with that kit?
Old Aug 20, 2010 | 09:39 PM
zer0t's Avatar
zer0t
You have one? Give us some impressions.
To Getting my E-Force installed
Old Aug 21, 2010 | 12:17 AM
Marc V.'s Avatar
Marc V.
Im ready to pull the trigger on an E-force pending positive feedback.
Old Aug 21, 2010 | 01:46 AM
10mikeymike
I got the standard LS3 kit, but had a Z06 fuel pump installed which produces the same results as the Edelbrock high output kit. The final pulley selection will be determined once the car is on the dyno. The blower bolts directly to the L92/LS3 heads, but it was necessary to machine the back of the blower cover to clear the firewall on LS2 equipped cars. According to Livernois, this is essentially what Edelbrock is doing to the units produced for LS2's. I expect to have the car back early next week. I'll let you know if it was necessary to move the sensor.
Old Aug 24, 2010 | 11:02 AM
bonecrrusher
Any updates on this?
I have this bookmarked - but I'm leaving the country this afternoon - I'll have to check it out in a week or too.
