C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Blowby
Old Aug 19, 2010 | 09:43 AM
d.medic's Avatar
d.medic
St. Jude Donor '10
So after stopping at 4 parts stores yeaterday and not being able to find the right PCV valve, Chris is just going to send me one. Thanks once again ECS for great customer service!
Old Aug 19, 2010 | 09:56 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Originally Posted by AVB
Here's how mine is set...
Red arrows are one-way checkvalves. The one towards the inlet of SC allows the system to continue letting blowby out when the system is under boost (other checkvalve closes). This has the added benefit of possibly creating a vacuum in the crankcase which I've heard let's the rings seal better.... maybe
I kinda dig that. Not sure how I feel about tee'ing the valve cover into the dirty side but I do like teeing the clean sides together. Do you say "added benefit" because there is no breather?
Old Aug 19, 2010 | 10:57 AM
AVB's Avatar
AVB
Why do you call it "dirty"? Either way, only one needs to be used and I'd use the one picking up the least amount of oil.
The "benefit" being it's creating negative pressure which is supposed to create a better seal at the rings. Not something I've proven but just makes me feel better. Plus, with this setup my oil pan no longer seeped/stained of oil so I know for sure crankcase isn't being pressurized.
BTW... it's important to limit the amount of vacuum from the manifold with a good pcv/checkvalve combo. If I put a breather in it would be on the passenger side and with a vacuum relief valve so it could be a source of fresh air to better evac and still retain vacuum.
