C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Blowby
Old Aug 17, 2010 | 12:39 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Default Blowby
So I have put about 800 miles on my new forged build. I have been keeping an eye out for oil consumption. I have none so far. What I have noticed is everytime I check the oil level I get a some white smoke coming out of the dipstick hole. Soooo, How much blowby is normal? If any at all. I have not cleaned my breather and plan on doing that today. Thanks in advance.
Old Aug 17, 2010 | 12:44 PM
TTZ06VETTE's Avatar
TTZ06VETTE
Catch can?
Old Aug 17, 2010 | 12:50 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
yes I have a catch can but I wondering if it got put on wrong during the rebuild
Old Aug 17, 2010 | 01:19 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
What is the application? IE centri LS2? Roots LS3?
Old Aug 17, 2010 | 01:58 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
2006 C6 coupe with an ECS 1500 kit. 800 miles on a rebuild with manley pistons and rods.
Old Aug 17, 2010 | 03:02 PM
5 Liter Eater
St. Jude Donor '11
Should look like this with the addition of the ECS oil cap breather.
Old Aug 17, 2010 | 06:39 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Thats how it's hook up. Am I just being overly cautious here?? I Have not seen any oil out of my breather or anywhere else for that matter. Just noticed that when I check my oil white smoke roles out the tube for about 5-10 seconds
Old Aug 17, 2010 | 07:01 PM
AVB's Avatar
AVB
If you don't see a drop in oil level your doing good. If there were any real blow-by you'd see it with decent velocity, coming out of a tiny dipstick tube.
Btw... the problem I see with that PCV/Catchcan routing is... when in boost the check valve will pretty much shut the line from the catchcan to the intake manifold. That means during times when under boost and when blowby will be greatest, the line from the valve cover to the inlet of the supercharger is what relieves crankcase of blowby. No catchcan there.
Old Aug 17, 2010 | 07:23 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
So i just went out and took a close look with the ECS instructions in hand. It looks like my catch can arrow is pointing towards my valley cover (that's the wrong way if I'm reading right) and I don't see any PVC valve. What the heck?? Could this have done any damage??
Old Aug 17, 2010 | 11:16 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Most newer cars do not have a pcv valve only an orfice to regulate the vacuum. It should have a check valve with the blower install.
Old Aug 17, 2010 | 11:50 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
I'm talking about the PCV valve that comes with the ECS kit. It's not installed. Now I wondering if all this could have damaged my new motor?
Old Aug 18, 2010 | 09:39 AM
5 Liter Eater
St. Jude Donor '11
That is the wrong way. You're pressurizing your crankcase when you go into boost. There is no PCV valve. I wouldn't expect any damage happened.
Old Aug 18, 2010 | 09:44 AM
5 Liter Eater
St. Jude Donor '11
That is true. I did say "with the addition of the ECS oil cap berather" though which should prevent that. The above diagram is an emissions compliant version although another catch can wouldn't hurt where you mentioned.
Here is an off road version that does not allow dirty air into the blower:
Old Aug 18, 2010 | 09:51 AM
d.medic's Avatar
d.medic
St. Jude Donor '10
According to the ECS install instructions the kit comes with a PCV valve the goes just before the catch can on the intake side. It is clear that this is missing. Do I not need it?
Old Aug 18, 2010 | 10:43 AM
5 Liter Eater
St. Jude Donor '11
PCV Valve = Check valve
Old Aug 18, 2010 | 10:45 AM
5 Liter Eater
St. Jude Donor '11
Wait, maybe I misunderstood. You meant the arrow on the air compressor catch can? And you don't have the check valve/pcv valve in-line? If thats correct then that is your problem. You need that!
The arrow on the air compressor catch can should be pointing toward the lifter valley but that is not critical.
Old Aug 18, 2010 | 10:51 AM
d.medic's Avatar
d.medic
St. Jude Donor '10
Yea I do not have the PCV valve inline. I have an email in to Chris to get the part number of the one i need. I thought the ECS instructions said the arrow on the catch can should point towards the intake, along with the arrow on the PCV valve.
To Blowby
Old Aug 18, 2010 | 10:55 AM
5 Liter Eater
St. Jude Donor '11
Like I said, the catch can arrow doesn't matter too much and kind of comes down to personal preference. It's rather in-efficient as a catch can anyway.
But yea, you need that check valve/PCV valve eh.
Old Aug 18, 2010 | 01:53 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Thank You for your help
Old Aug 18, 2010 | 06:40 PM
AVB's Avatar
AVB
Here's how mine is set...
Red arrows are one-way checkvalves. The one towards the inlet of SC allows the system to continue letting blowby out when the system is under boost (other checkvalve closes). This has the added benefit of possibly creating a vacuum in the crankcase which I've heard let's the rings seal better.... maybe
