C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
First Impressions / E-Force on LS2
Old Aug 31, 2010 | 08:03 PM
vertC6's Avatar
vertC6
I would love to hear it idle!
Old Aug 31, 2010 | 10:10 PM
SpinMonster's Avatar
SpinMonster
Has edelbrock made any warranty claims concerning the use of meth injection? It works great on the KB twin screw. I just added it to a friends car with the KB 2.8. Its 100% meth. It cools the IAT chanrge to a lesser degree but it shows on the scans. The real benefit is the octane.
Any plans to add it to your car?
Old Aug 31, 2010 | 10:35 PM
10mikeymike's Avatar
10mikeymike
I'm not sure what Edelbrock's position on meth is. I thought I read somewhere there's a coating on the screws that can be affected, but perhaps this was for something else. At the moment I don't have any plans to add meth, but I wasn't planning to do the mod's that were just completed either. I was entertaining trading the car for a while, but as soon as it was paid for I decided to start playing with it. I managed to leave it alone other than cosmetic changes as my street rod is what I'm normally tinkering with. Now that I've begun to make some serious performance enhancements to the Vette who knows? A new radiator is definitely the next mod. What's next - meth, nitrous a rear end? This can be contagious!
Old Sep 1, 2010 | 09:26 AM
vertC6's Avatar
vertC6
I would first try what 5 liter eater suggested first, program the fan to turn on a little sooner and kick up to 90% at 200-205, and add more distilled water and water wetter and see what that does first.
Old Sep 1, 2010 | 11:46 AM
10mikeymike
I still plan to replace the radiator, but between now and then, I will do some experimenting. I took the car out last night after the temp's. dropped into the low 80's. The coolant temperature averaged between 208 & 210. Earlier after driving home in medium heavy traffic and 91 degrees it got up to 226. After I shut the car off the fan came on and ran for close to 5 minutes. I've noticed that it always seems to be running when I turn the car off. This was the first time it came on with the ignition off. It's amazing how much heat the Edelbrock coil covers retain. They really make the install look good, but I think they exacerbate the heat situation.
Old Sep 1, 2010 | 12:51 PM
cthusker's Avatar
cthusker
I have one being installed in a couple weeks by ECS. I'm replacing the rad right there and it should help with the cooling situation. I plan on running with the coil covers off during the summer. I've been monitoring my IAT's for the past month and amazed how hot it gets under the hood with a bone stock car! Let it idle for 10 mins on a 85 deg day and you're talking about 150 degs and up. So it's already a boarder line situation with under hood temps before you even do the FI! In any event just something I'll have to deal with on hot days but it's not stopping me from doing the install.
Keep us posted on how it's working for you.. and thanks for posting!
Old Sep 1, 2010 | 01:39 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
It's labor intensive but yanking the condensor and radiator and blowing/tapping out the crap that gets lodged in there helps as well. I could have re-seeded my back yard with what came out of mine.
Old Sep 1, 2010 | 02:12 PM
Motorhead-47's Avatar
Motorhead-47
on the coil covers holding heat...mine only go on for show/photos...spend the rest of their time on the shelf
Old Sep 1, 2010 | 03:02 PM
old motorhead's Avatar
old motorhead
I'd sure clean it before spending the cash for a new radiator. My LS3 with maggie TVS has no heating problems. It will get up to 190 to 195 in stop and go traffic. 180 to 185 at cruise. I can let it idle with the a/c on for 5+ minutes standing still and not get over 210. That's in 95 degree heat. I have an M6....maybe that's the difference.
Old Sep 1, 2010 | 05:06 PM
10mikeymike
I've already committed for the radiator and I'm sure it can only improve things. In the meanhwhile, I think I'll experiment with the coil covers off and see what kind of difference that makes. It's been in the 90's here for the past 4 days. The beauty of living in Michigan is that it's only supposed to be in the 60's this weekend. Unfortunately, it could snow the week after next and I'd have to put the car away till Spring.
Old Sep 1, 2010 | 06:41 PM
62Jeff's Avatar
62Jeff
I just picked up my 2007 from EnglandGreen on Monday. Bone stock until they installed the E-Force and a DeWitt's radiator.
I see coolant temps of 185 cruising down the highway, nothing higher than 205 after sitting at a stoplight in the heat with the A/C on full. Coolant is a 50/50 mix of Dexcool.
The DeWitt's doubles the radiator capacity and eliminates the plastic tank ends, for me the upgrade while doing the radiator was an easy choice.
Old Sep 1, 2010 | 08:54 PM
vertC6's Avatar
vertC6
My guess is your hood has something to do with it too, being that it is open in the back with the cowl, and allowing that air to pull through the engine compartment.
Old Sep 1, 2010 | 11:17 PM
  #33
10mikeymike
Thanks for posting this information. This helps to reaffirm the need to do this. In retrospect I wish I would have just did it while the car was apart. Was there any particular reason you chose the DeWitt's over the BeCool or another brand? Enjoy your new E-Force.
Old Sep 1, 2010 | 11:26 PM
  #34
62Jeff's Avatar
62Jeff
I would never have thought about the cooling system until I started reading threads about A/C systems cutting off when the engine coolant got hot on supercharged cars. Living in Houston, where it's been between 90 and a million degrees outside lately, I didn't want that situation and after consulting with my tuner, I decided to upgrade the cooling system while they had the car apart.
Yes, I have DeWitt's in my 62 and 65 vettes and find their quality to be beyond compare. So I wanted to give them my business for the 07 as well. Having a manual transmission car without the Z51 package, the radiator for me is
http://www.dewitts.com/pages/product...asp?ProdID=380
I had them include their black-ice coating (black paint) so that it would hide in plain sight in the car.
Old Sep 2, 2010 | 08:53 AM
  #35
j_digi454's Avatar
j_digi454
Jeff & Mikey, great stuff as I'm thinking about this same FI system, thanks for posting.
Old Sep 2, 2010 | 08:35 PM
  #36
VETFEVER's Avatar
VETFEVER
At first glance I thought the pic was photoshopped - but ouch it is real!
But you know it would make one crazy avatar pic, almost like the Lexus is trying to lay a kiss on your Vette - I'll go away now :o
Originally Posted by Motorhead-47
........a very sad sight to see when I went to lunch back on 20 July!
Old Sep 2, 2010 | 08:42 PM
  #37
VETFEVER's Avatar
VETFEVER
On a more constructive note - a Z06 exhaust rigged up so that you can manually control the flaps is a nice way to go - I have this on my pro-charged C6 and I use the home link buttins on my visor to manually open and close as I wish. The 3" Z06 exhaust doesn't restrict and sounds great. You can also do the Z06 mod on the cans if you want some nice barbling action when you let off the gas. Known plenty of guys who have gone the louder exhaust route at the same time they installed a bunch of other power mods and many have eventually gone to something quieter...
To First Impressions / E-Force on LS2
Old Sep 2, 2010 | 10:02 PM
  #38
10mikeymike
I kinda feel as though I'm in an arranged marriage. I'm trying to fall in love, but it's either going to take a while or we just weren't meant to be. When I got the car I immediately put Corsa Sports on it. I didn't care for the way they looked from behind the car so I switched to a Magnaflow system. I like the looks of the Magnaflow's, but always felt they were too quiet. I bought the GHL's because I liked the idea of not having to align the tips. Each side is 1 piece consisting of tips, small mufflers and the over the axle pipe. They look great and sound teriffic from outside at idle, in drive by's and under hard acceleration. Unfortunately, they make your teeth hurt on the inside under any level of acceleration. I always joked around and said my Vette seemed like my Lexus with 2 seats. Now, with the mod's and exhaust it's every bit the hot rod my 37 Ford is. It surges, it bucks, it's loud, but man is it fast!
Old Sep 2, 2010 | 10:41 PM
  #39
5 Liter Eater
St. Jude Donor '11
Do you know the specs on the cam? Putting a cam that bucks and surges on an E-Force install kind of defeats the purpose.
Old Sep 2, 2010 | 11:23 PM
  #40
10mikeymike
The reference to bucking and surging was a bit of an exaggeration. There's a small amount of surging at off-idle speeds and a little bucking on trailing throttle deceleration. The combnined result of the performance mod's. changed the car's personality from mild mannered to much more agressive. The cam has blower friendly spec's. of 224/236 .612/612 with a 118 LSA.
