i just installed a d1 on my 06 z51 and the car is scraping on everything. i have destroyed the lower valance already. i dont know if this is a common thing or not with the weight of the supercharger kit. i bought the car used and i think it might have been pulled down in the front but not sure. if anybody could help me out with some info on this i would appreciate it thanks steven
I'm not sure on the specifics of your kit, but I scrap EVERYTHING with my ECS/Paxton setup. My guess is it's because the radiator cradle has been lowered and pushed slightly forward. I'll go out and take a couple pics of my "ground clearance."
Oh well, it's worth it!
From: Greater Detroit Metro MI, when I'm not travelling.
Originally Posted by 5 Liter Eater
The cradle gets lowered slightly but moreover the extra weight on the nose lowers the front even more. Raise the front back up. Easy peasy.
Precisely. I made the same post 2 days after my supercharger install. The front lowers itself from the weight and you lose about 3/4" off the cradle to ground clearance since it is lowered to fit the intercooler. I raised my front back up on the stock bolts and now it is not so bad.
I also HIGHLY recomment those little wheels (A&A sells them) that bolt on your cradle so it rolls over things instead of scraping them. Never going to have a 'Vette without them again!
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The extra scrapping is more so from lowering the cradle a bit, and moving the air dam a bit forward of the fulcrum point, (the tire) over the weight added IMHO. The shipping weight of the kit is in the 60's, (I do not recall exactly, but I think it's 67lbs) then theres what is removed, my guess is 10-15 lbs? So that adds 52-57lbs. That roughly the same weight as half a tank of gas.
A slight riase of the front spring will take care of that like you suggested.
I have a procharger on my 05 and I had to trim about a inch off of
mine and it still drags a lot. I ended up taking the two side pieces off because it didn't look right with the middle airdam trimmed. I do not have any cooling issues at all in case that is a concern for you.
When you taper the side pieces it looks continuous.
