ZR1 gearset?
I've been thinking about ZR1 gearing for my (still uncompleted) project. The goal would be to make first gear hook better in my normal setup, which should be 700-850 rwhp with PS2 ZPs (yes, I know). The better top end gearing is also a plus.
Yesterday I got to drive a lightly-modded (headers, cold air, tune) ZR1. I felt that first was not too tall, and that it did, in fact, make the car more useable in first. So, that mostly took away my worries about it being too tall for stop&go traffic, etc. So I was just wondering what other guys thought.
As for my own project, the tranny will have to be a "Day 2" deal, as right now the focus is just getting it on the road. We're gettin' there.
I will be running stock 342 gearing out back. RPM built me a stout rear end with their 300M axles, I have a Driveshaft shop 1000hp prop shaft that is also going into the torque tube so the drivetrain should be stout enough. I have new 345 invos coming mounted on CCW C140s with a 19-19 wheel combination. CCW says I will have the first set of these C14s in 19" on all four corners since getting their new 19" forgings in stock.
I know there are many centrifugals making more but they don't make the torque off the bottom end as a TVS will, which will make this a real fun street car. My suburban has a 8.1L big block, and it has a large Whipple stuffing air into the engine, let me tell you that truck flat hauls for a 6900 pound shoe box. It drives like it weighs about 3000 pounds less! I am not looking for fast 1/4 mile times, just a fun car to drive and showcase for my shop, it will be plenty fast for me
Here is my LS7 with my little boy riding the Maggie:
I can' wait to get it in and running. I got all these goodies and no time to do the work!
Your car will be a ZO6 on steriods! Nothing to fear from ANY ZR1
on the planet!
G-Force is only company to my knowledge that makes aftermarket gear sets for our trans... RPM uses their stuff on high HP builds. Maybe give them a call to see if they started working on T6060.
Mike
Im hoping to have a solution soon... (hint to solution provider, Im still waiting...
If you never drag race, the ZR1 is the best option. The close ratio is the cats meow, with out a doubt. If you have a mile car, and you go faster than 205, the ZR1 5th is NOT the best, its too short. The Z06 5th is the best.
If you want to keep both worlds- Z06 1-4, ZR1 5th/6th.
The Z51 has too tall of a drop 3-4, as well as 4-5.
If you use a ZR1 transmission with a 4.10 differential you end up with almost identical 1st gear as a base/Z06 transmission with a 3.42 gear and you get the super close ratios.
Give us a call if you have any questions, I would be glad to go over some things with you on what we can do.
Thanks,
T.J.
Thanks,
T.J.
I have a Z51 coupe.
I know you guys charge $350 for a gear set swap.
If i wanted to buy a Built 6060 with coupe 1-4 and the Zr1 5/6 with the z51 tranny cooler provisions would it be +$350 for gear set swap and +another $350 for zr1 5/6? or is that all in the initial $350?
Im pricing out a Stage 5 tr6060 with Z51 provisions, but Coupe ratios and zr1 5/6
thanks in advance.
