C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
08 diff gear sets. Is anyone producing any?
Old Mar 13, 2011 | 08:52 PM
Smoove's Avatar
Smoove
Default 08 diff gear sets. Is anyone producing any?
Very interested in the ZR1 gearbox(TR6060) or possibly the Z06 variant, with the 08 diff but,...the 3.42 gear set,..is going to kill my possibilities of going higher then the low 200's in the standing mile. Is anyone that you know of, a vendor or anyone, planning on doing gears for these? I am interested in a 3.08 or even numerically lower. I know it's a shot in the dark but,..I am interested. If not, I need to rethink options.
Thanks.
(I did search-pulled nothing informative up)
I am not planning on going above 6500-6800 in the mile. 335/35/18 inch wheels...for the number crunchers.
Old Mar 14, 2011 | 12:15 AM
tpereira's Avatar
tpereira
Thanks.
contact ECS.... they are doing this for me as we speak (t56 built with tr6060 ZR1 gears while keeping the 3.42's).
http://www.car-videos.net/tools/spee...B1=Recalculate
Old Mar 14, 2011 | 12:26 AM
tpereira's Avatar
tpereira
Just saw your post in the other thread... didnt realize your looking to go more than 221 and break records... better have plenty of power for that
Old Mar 14, 2011 | 08:03 PM
Smoove's Avatar
Smoove
Thanks bud,...got the power covered. I want to change the DIFFERENTIAL gear,...not the TR6060 gearset(I wantthe TR6060 trans with ZR1 gears but with a different diff gear-not a 3.42).
Thanks.
Anyone else?
Old Mar 14, 2011 | 09:05 PM
saplumr's Avatar
saplumr
Thanks.
Anyone else?
You need to talk to RPM. They're as good as it gets!
Old Mar 14, 2011 | 10:23 PM
Smoove's Avatar
Smoove
You know what,..your probably right.
Good call.
I'll start there. Thanks-
Old Mar 14, 2011 | 10:28 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
My guys can build you a differential (base differential ring gear size non-Z06/ZR1) and use the following ratios.
2.56
2.73
2.93
3.15
3.42
3.73
3.90
4.10
The differential will be built to be a direct bolt in and fit the ZR1 TR-6060. It can also be built using a rear differential fluid cooler pump as well along with many other options.
Old Mar 14, 2011 | 11:12 PM
Slvr08Z51's Avatar
Slvr08Z51
2.56
2.73
2.93
3.15
3.42
3.73
3.90
4.10
Is the base differential ring gear as strong as the Z06/Zr1?
Old Mar 14, 2011 | 11:17 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Hey Jamie...run zr1 6060 and 3:42.
Old Mar 14, 2011 | 11:19 PM
NICK YOSKIN
St. Jude Donor '08
Btw order ur tranny now and maybe ull have it before may event! Blah
Old Mar 14, 2011 | 11:20 PM
White_Lightning's Avatar
White_Lightning
the Z0 rear diff is bigger/stronger from what i have been told..
when you put gears in a z0 rear you have to put in a smaller carrier and basically makes the rear weaker..
that being said.. there are lots of cars going fast with base rear ends.
Old Mar 14, 2011 | 11:25 PM
Slvr08Z51's Avatar
Slvr08Z51
Maybe..
Old Mar 14, 2011 | 11:44 PM
Former Vendor
Originally Posted by WhiteLightning_
the Z06 rear diff is bigger/stronger from what i have been told..
when you put gears in a Z06 you have to put in a smaller ring/pinion and case and basically makes the rear weaker..
Absolutly correct
Old Mar 15, 2011 | 01:34 AM
TrenAman's Avatar
TrenAman
RPM all the way... this is just a fact.. look no further..
Old Mar 27, 2011 | 04:39 PM
Smoove's Avatar
Smoove
lol, I heard they were difficult to get.
2.56
2.73
2.93
3.15
3.42
3.73
3.90
4.10
Awesome Rodney, sounds like the route I need to take.
I will but, not for the street. I think it will be spin city, and not super useable. Not only that, I think I will run out of RPM with that trans and gear set before the end of the mile... in theory anyways. What, 203mph at that RPM?... in 6th? Not enough if I wanna do better then average in the standing mile. For the drag strip....I am with you!
Awesome, great to know.
My bad for the delayed THANKS,...been a lil occupied.
Old Mar 27, 2011 | 05:35 PM
tpereira's Avatar
tpereira
Where you getting 203 ? the top speed of the ZR1 ?
click this...
ZR1 is gear limited to 221.1 mph
Old Mar 27, 2011 | 07:41 PM
wilson34's Avatar
wilson34
^I bet 6th would be a little to hard to pull in the mile.
To 08 diff gear sets. Is anyone producing any?
Old Mar 27, 2011 | 07:46 PM
Smoove's Avatar
Smoove
click this...
I`ve never done the gear math on a ZR1,...I am only going based on what I read on the internet,...of someone saying all they got out of a Zr1 was that speed,..at a higher RPM then I wanted.... shame on me for being an internet douchel(I am saying this jokingly not offensivly or defensivly) on the ratio/speed. However, I have done this math multiple times with my current gearbox and setup.
But,..since we're here now,... doing the math for that trans spec, and doing the math for my 18" wheels, @ 6500 rpms, I am looking @ 211mph with that gearbox and 3.42's ....
..am I not?
If soo,..thats just not gonna do it for me man. Not gonna go through this trouble to NOT go in the 220's. I don't see that happening with a 3.42 and that box.
Old Mar 28, 2011 | 12:10 AM
tpereira's Avatar
tpereira
..am I not?
Two options...
Z06 Trans with 4.10's http://www.car-videos.net/tools/spee...B1=Recalculate
ZR1 Tran with 3.15'shttp://www.car-videos.net/tools/spee...B1=Recalculate
Any as far as I know the Z06 diff can use 4.10's with the Eaton Diff Carrier that ECS sells (just using regular c6 gears).
4.10's in a Z06 Diff
http://forums.corvetteforum.com/1575746693-post18.html
Ratios Available
http://forums.corvetteforum.com/1575749957-post21.html
I think better perfomance in the mile is ZR1, and its better for daily driving. You give up 1/4 mile performance
Old Mar 28, 2011 | 12:20 AM
tpereira's Avatar
tpereira
just need enough power... the zr1 doesnt have it...
