You could just use diode's to block the signal/converter from entering the abs wiring. That way the box would get a signal, But no feedback to the abs module.
Ok, so basically allow the forward direction of the diode to go towards the box so current could pass and it would be blocked back into the wheel speed sensor wiring.
I went to RadioShack and bought some diodes, resistors, and transistors. I guess Ill try to solder the diodes in first since they seem the easiest unless someone far more knowledgable in this area tells me different.
Nick, I'm curious how you wire it into one of the front wheel speed sensors without it throwing the ABS/TC CEL?
I wired in a box made by GSS to work with the Eboost2 and its throwing the ABS/TC light with a C1233 code, meaning the RF wheel speed sensor circuit is open/shorted.
update....
i had other issue to deal with and finally got around to installing and its throwing ABS/TC
now on this box has has the abilty to be in either hi or low impedence. it is currently hooked in Hi. i need to get some resistors 2.5 5, 10 and
start with the lowest and see if it cures the issue. if i go to high then the controller my not work as designed though.
chris you cannot just hook up the boost controller straight to the wheel speed sensor. you run the chance of toasting ur EBC! the signal off the speed sensor is DC
Nick,
I have the one offered by LG/GSS because it is the only one offered to work with my boost controller and is supposed to be an easy hook-up. I'm sure it already has the voltage divider and has already been tested.
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by NICK YOSKIN
thanks!
hey doug hope all is well with u and ur family.....
miss u guys!
wanna do a ECS barbaque? ill bring the burgers!
We are going to have a big barbaque this summer Nick! We have an annual run and meet up here each summer for our former shop manager Johnny who passed a year and half ago to help out his wife and two kids.
I have your cell, I'll give you a call when.
Nick,
oh!
ok yeah that was designed by a guy who does traction control for outlaw cars. yeah i need to test here w/resistors...will let u know.
yeah man that is sooooooo sad!
remember when i was at ur place and i went to WAWA and got a bunch of ice cream and me a jonnny ate is all!!
i assume that u have a power and ground for the unit along with common and signal for the wheel sensor. run the ground to the common on the wheel sensor and see if that works.
