C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Difficulty level for installing AA kit?
Old Mar 28, 2011 | 12:35 PM
71'AirStrike's Avatar
71'AirStrike
94-vette's comments are a little harsh, but have merrit.
AtomicLS3,
installing a S/C can be done and its not impossible. A lot of us here were 'first timers' once. What I will offer tho as some advise.
If you are streching $$ to get a used kit, then dont.
You dont know what you are missing (if anything), or what lookes used/worn. You have nogthing to base it off of.
For your first time out of the gate buy a COMPLETE NEW kit from A&A or ECS (or many other fine vendors here).
Then you know you will have everything and it is in good working order.
Food for thought: If you think buying a new S/C kit is expensive. Imagine how much a new engine costs.
cheers
cahd
Old Mar 28, 2011 | 01:27 PM
Robls6's Avatar
Robls6
I agree with the others about buying a used kit. It will most definitely cost you more in the long run. A&A makes a damn fine kit that can be installed yourself if you take your time. Make sure that before you drive it hard (or at all if possible) that you have it properly tuned. Good luck and have fun!
Old Mar 28, 2011 | 03:55 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Originally Posted by AtomicLS3
I am most likely going to get a AA kit for my 08 c6 and wanted to hear the opinions of people who have installed their own kit by themselves. I am pretty knowledgable about cars and work on all my toys. I have a lot of tools in my garage. So how difficult is the entire install from 1-10? How long did it take? Did u run into any snags? Can you drive your car once finished to the runner or does the car not run right? Thanks
Give me a shout if you want...
Old Mar 28, 2011 | 04:13 PM
AtomicLS3's Avatar
AtomicLS3
Thanks guys, you have swayed me into buying a new kit. When looking at the AA install guide it looks like there are a ton of little pieces that you need and it would probably be a hassle to find them all separate. Do self contained units offer any performance disadvantages?
Old Mar 28, 2011 | 04:34 PM
Former Vendor
Performance-wise The V-2 and V-3 are the same.
Old Mar 28, 2011 | 06:01 PM
Motorhead-47's Avatar
Motorhead-47
Originally Posted by Motorhead-47
Drop the cradle...lift the engine...pin the crank in under an hour
Quoted myself
I'm not sure people are seeing the significance of this photo. What you are seeing is clear access to the crank bolt with the steering rack in-place. Simply loosen the 4 nuts down to the last couple of threads that hold the engine cradle, then remove the two motormount nuts, followed by raising the engine with a floor jack. Beats the crap out of pulling the steering rack..a lot less time and a lot less mess!!!
Old Mar 28, 2011 | 08:51 PM
71'AirStrike
thats it?
remove the radatior?
need a special 90* drill?
Doubble jointed wrists?
wow... im going to save thsi thread.
Old Mar 28, 2011 | 08:57 PM
Motorhead-47
Fan has to come out but that is two bolts and a harness plug.
Magnacharger does it that way....Starts at step #56 http://www.magnacharger.com/pdf/manu...ntercooled.pdf
I've done it both ways...the last was drop the cradle method. I'll never use the pull the rack method again
Old Mar 28, 2011 | 09:06 PM
Streetk14's Avatar
Streetk14
Quoted myself
I saw it and kinda wish I'd done that instead of pulling my rack again (had it out for a cam swap last year).
But then again, I don't think pulling the rack is all that bad. The more tire consuming stuff for me was getting all the charge pipes and BOV where I wanted them, cutting the bumper, cutting the wheel well cover, modifying the heater hose (not required), etc. Basically, all the small stuff that I wanted to be perfect. I also changed the radiator and intake manifold during my install.
If I were flat-rating this job on someone else's car, it would probably be a different story.
Old Mar 28, 2011 | 09:11 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I've been with Ken on several installs with mine being the first. Anyone with a Z51 optioned car will appreciate the cradle method over the rack method. If we had known about the cradle method when we did my car we would have saved hours and several DNA deposits in the engine bay.
Old Mar 28, 2011 | 09:20 PM
Motorhead-47
Pulling the rack isn't that bad but the other method is mucho easiero!
Old Mar 28, 2011 | 09:37 PM
AtomicLS3's Avatar
AtomicLS3
Thanks for the suggestion, sounds like it makes the install a lot easier.
Old Mar 29, 2011 | 11:45 AM
  #33
JesseBBB's Avatar
JesseBBB
[QUOTE=Motorhead-47;1577189045]Quoted myself
I'm not sure people are seeing the significance of this photo. What you are seeing is clear access to the crank bolt with the steering rack in-place. Simply loosen the 4 nuts down to the last couple of threads that hold the engine cradle, then remove the two motormount nuts, followed by raising the engine with a floor jack. Beats the crap out of pulling the steering rack..a lot less time and a lot less mess!!![/QUO
Thanks for the great tip, getting ready to install my A&A S/C Kit this weekend on my 05 should make things go a lot quicker. I am a more nervous about tuning the car with my HP tuner software then the overall kit install.
JesseB
