C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
super charger
Old Mar 28, 2011 | 08:52 PM
2000droptop's Avatar
2000droptop
St. Jude Donor '07
Default super charger
In the market for a supercharger producing in the 625 hp range (at the crank). Anybody running around those numbers? Do in need to replace the clutch with an aftermarket clutch or will the stock on do the job? any additional drive line tweeks to handle the extra ponies?
Old Mar 28, 2011 | 09:01 PM
Robls6's Avatar
Robls6
625 at the crank is easily attainable with pretty much any centri supercharger kit. I really like my A&A on my 07 car. I have over 14,000 supercharged miles making 570rwhp (over 650 at the crank) and have had no major motor issues at all. I did break the mainshaft on the trans which was quite costly to replace (with an RPM level 5). Stock clutch will not last very long unless it's an LS7 clutch, and even that will be maxed out. I've had no problems with my LS7 clutch so far, but know eventually it will need to be replaced.
Old Mar 29, 2011 | 12:50 PM
2000droptop
St. Jude Donor '07
Thanks for the input
Old Mar 29, 2011 | 05:45 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Plenty of people running in the power range around here.
Old Mar 29, 2011 | 06:22 PM
MARSC6's Avatar
MARSC6
I've been around that hp for 3 years without any clutch or drive line problems with a ECS kit. It all depends on how you drive.
Old Mar 29, 2011 | 06:37 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Well said. Most of the cars that leave here are more or less stock including the clutch and drive line, and most stay that way for a long time. However, if you know your going to be rough on the car, race it etc, then plan on things like a clutch, tires, shaft in the diff to start with.
Good luck with your build, let us know if we can help answer questions for you.
Old Mar 29, 2011 | 08:43 PM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
I know that I love to smash the GO pedal, though I no longer have much desire to set land speed records, it is very fun to be able to haul some ***
For the power level of my new build (I'm guessing about 600rwhp), it's probably overkill but I'm upgrading the axle/hub, torque tube, output shafts, transmission, torque converter, and going to coilovers. Labor is so expensive that it kind of makes more sense to do it now while everything is out
Old Mar 29, 2011 | 11:30 PM
Spying Beast's Avatar
Spying Beast
Stock clutch will hold up just fine so long as you're driving like a normal human being and not like the rest of these animals!
Old Mar 30, 2011 | 12:48 PM
2000droptop
St. Jude Donor '07
Again,thanks for the input it's much appreciated. Since I drive with a level head and do not track the car it sounds to me like I can probably live with the stock setup from the clutch back.
Old Mar 30, 2011 | 12:50 PM
2000droptop
St. Jude Donor '07
Appreciate your post,thanks
To super charger
