Quick question(s) for you guys with crazy hp. Just curious to see how you guys made the transfer from a "normal" car, to getting in one with 800+ or even 600+ hp and controlling it.
How do you learn to drive with all of that power?
Were there any "Oh S***" moments when you were not a custom to the power?
Thanks,
Philip
Let off the gas. You learn what spots you can hammer it and when to let off the gas. You can control a lot with the just the throttle. I can stick 2nd gear with 700+rwhp. The key also, is a good set of rear stickies. Believe it or not, you get used to the power, even when pushing 800rwhp.
I suggest going to a road track rental type day with a stock to bolt on level car and push it way beyond it's limits. Spin out, over correct with snap over-steer etc. Get the feeling of the car when it's about to cross that line(and cross it) in a safe place, that way you won't do it when it could mean your life.
Don't show off. The #1 cause of losing it is going to be showing off. Trying to drift that long burnout down the street isn't worth it when you F it up and end up in a building. Even pros lose it so don't think you're anything special.
Be patient. The experience will come with more and more trips to WOT. Don't be in a hurry to feel what the car is like with your foot on the floor. Try out 75% throttle for a while and slowly increase your trips to triple digits with more and more throttle. You'll be used to WOT in no time so don't be in a rush.
first : you need common sense and a good feel of the car and its power
second : a boost by gear setup that distributes the power to each gear http://www.turbosmartonline.com/index.php?id=42
what are you using for boost by gear? the e boost2 has the capability but doesnt do the actual boost by gear. are you using micro switches or boost by speed by the wheel sensors.
Thanks,
Philip
I think the most important thing is knowing how to control the car and how to react in low-traction situations. I haven't had a "normal" car for a long time- always something with at least 500 flywheel hp for the last 12 years. In that time I've done some stupid stuff, but have learned how to control a burnout and high speed tire spin.
I also did a couple days at BMW's M driving school (was free with my M3) that was really helpful. In addition to the regular track stuff, we did laps around a polished concrete/flooded skid-pad learning how to drift in M5s.
I really need some new tires. At 661 rwhp, I'm spinning my supercars in the first 3 gears and it will lose traction at close to 100 mph. Even with the traction control "on", you have to be prepared to control the car. I've found it really will not save you with this much power.
wont work for me my cars a 2011 the boost by speed by GSS is only up to 2009 or 2008 i forgot what Louis said. they changed the way the front wheel sensors work on the 2010 and up
yes im using a switch plate that's mounted in the gear box shifter gates
When my car was in the 600whp range, it actually became easier to modulate the power with the stock F1's.
Rolling burnouts at 70mph were easy, fun and kind of cool.
However, that gets old, and I invested in a set of Kumho V710 road race tires, which worked very well and lasted very well, surprisingly.
If you are going to make big power, I think the best money spent is on a good, sticky set of rear tires.
They might wear faster than a stock type compound, but they will help greatly in keeping things under control.
Personally, I would run a road race tire rather than a DR.
If you need to, they can be grooved for better wet weather use.
Thanks,
Philip
Simple -don't floor it everywhere. Throttle control comes in handy.
i just got boosted... .and now with 600 to the wheels you REALLY need to RELEARN how to drive... no longer can i shift and hit a gear then pretty much go WOT right away... now its more of a roll on ... otherwise you just roast the tires and lose it !
