C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Autometer Gauge Problem
Old May 16, 2011 | 02:30 PM
-fate-'s Avatar
-fate-
Default Autometer Gauge Problem
We are having a fuel pressure gauge problem on the new E Force install. We are on the second fuel pressure gauge and this second one is doing the same thing. Showing 60 psi when working and will return to zero psi when you shut down the car. They work fine a week are so and then you fire it up one time and the gauge goes to 27 psi and never moves again. Changed it out.... second one runs a couple weeks...goes to 52 psi, never moves again. Waiting on the third gauge now.
These are the A Post gauges from Autometer, Boost and fuel pressure.
Anybody got any ideas, everything else is fine with this car, nice nice system.
Old May 16, 2011 | 02:33 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Are you using 12v or 5v for the source? Some sending units need 5v (IIRC)
Elmer
Old May 16, 2011 | 02:42 PM
-fate-'s Avatar
-fate-
12 volt
Old May 16, 2011 | 02:50 PM
eboggs_jkvl
Moderator emeritus
What do the instructions say? You may need 12v for the gauge light and 5v for the sending unit.
Exactly what gauge do you have?
Old May 16, 2011 | 03:08 PM
-fate-'s Avatar
-fate-
It is exactlly by the instructions. They are Autometer A Post Boost and Fuel Pressure. We got the hot off a 12 volt accessory downstream of the lights. That should handle it perfectly. The lights in the gauges continue to work no problem, in both failures I have not lost the light.
Old May 16, 2011 | 03:14 PM
eboggs_jkvl
Moderator emeritus
Ok. So, you have received 2 bad head units and you're waiting for the third try?
I saw 12v from the battery switched for red wire, black to ground, white to dash lighting, correct?
Old May 16, 2011 | 04:00 PM
-fate-'s Avatar
-fate-
Roger
Old May 16, 2011 | 04:03 PM
eboggs_jkvl
Moderator emeritus
I did read something on their site about each gauge has a specific sending unit. I wonder if there is a miscommunication in that area? Your wiring sounds fine.
Old May 17, 2011 | 02:16 PM
-fate-'s Avatar
-fate-
MMMmmm...let me take a look. They are saying it could be voltage surge
To Autometer Gauge Problem
