C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Meth Injection
Old May 19, 2011 | 02:23 PM
jthurik's Avatar
jthurik
Default Meth Injection
so I am using the windshield wash tank to hold the Meth and was wondering if anyone has found a good small tank to put some washer fluid into just in case I run into the random bird.
John
Old May 19, 2011 | 04:15 PM
eric04's Avatar
eric04
Old May 19, 2011 | 04:31 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
We have these in stock for $35
They work great....
If there is interest, I can set these up with the tank pump, a harness, lines....etc....
Old May 19, 2011 | 04:36 PM
breecher_7's Avatar
breecher_7
You can wash your windshield with methanol actually.... Im being serious......
Old May 19, 2011 | 04:43 PM
Le Mans Z06's Avatar
Le Mans Z06
I would love methanol all over my paint. Mike I am too scared to press my button for washer fluid, what happens if I do? Does it spray methanol all over my windshield? I assume not, but never asked. Honestly I carry a small bottle of windex and paper towels in my compartment in the back.
Old May 19, 2011 | 04:48 PM
Robls6's Avatar
Robls6
Washer fluid is actually more than 40% methanol anyway. There isn't anything wrong with using the meth to clean your window. I did however disconnect the washer pump when I installed my meth kit, but you probably could keep it connected and use it if need be.
Old May 19, 2011 | 04:52 PM
Le Mans Z06
Hmm...good point I had forgotten that it already contained methanol in washer solvents. I was told to make sure the methanol doesn't touch the paint, is that a big deal or can I just wipe it off if I get some on it?
Old May 19, 2011 | 04:56 PM
breecher_7's Avatar
breecher_7
As stated above, there is menthanol in washer fluid.... Its not going to hurt anything.
Old May 19, 2011 | 06:15 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In V Veteran
Meth is corrosive.... I wouldnt want to use straight meth to spray my windshield, esp given its price. Would it hurt anything, not likely. But I wouldnt do it intentionally if I could help it.
When we install meth systems here we always disconnect the pump. Youcan try to spray your windshield, but it wont work.
Old May 19, 2011 | 06:54 PM
breecher_7's Avatar
breecher_7
Ive been doing it for years, granted I only use the washer if i need to.... BUT, the fact is that its not going to hurt anything if you happen to use it.
To Meth Injection
