Boosted C6Z advise requested
Is an alky system the same as meth system? I know what a meth system is. If not the same what is the difference and when would you use which. Not trying to highjack. I think this pertains.
Thanks,
Rich
Thanks,
Rich
This will require him to have a fuel system capable of 900rwhp to get the job done. Problem is the OP is talking about boost-a-pump and 60lb injectors to get him the fuel he needs. If his shop was worth a damn they would know that he will need a heck of alot more than 60lb inj. a boostapump and stock lines to get him to what his needs are. Sure if he runs big enough injectors and the boost a pump he might be able to get away with it with his rev limiter lowered to like 6K or less and seeing a HUGE drop in fuel pressure to like 20psi or less under boost at higher RPMS.
OP will then need to do the full fuel system and then pay AGAIN to dyno tune his car.
Some people have to learn the hard way.
I tested ARH back to back with stock manifolds and only picked up 20 RWHP. BUT, I picked up a ton of torque down low.
The headers helped EVERYWHERE. There was not a single point on the graph that the headers did not help.
It was a VERY noticeable difference in part throttle response.
I will agree, however, that the FAST is a waste of funds.
But what do I know?
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
But what do I know?
I understand all the desires of the op on his setup. I wouldn't do it. But, could you help me with the meth vs ally question?
Thanks,
Rich
Thanks,
Rich
Gasoline is far more corrosive than ethanol is. Virtually everything that is designed to handle gasoline will handle ethanol as well.
Read this:
http://www.coleparmer.com/techinfo/chemcompresults.asp
Maybe also take a chemistry class while you are at it. I hate all the people on forums across the internet spreading misinformation about ethanol simply because they are naive and uneducated.
:smas h:
Read this:
:smas h:
You may want to talk to those flex fuel engineers that don't put aluminum or rubber into their systems, also? Do Z06 have aluminum and rubber in their direct line of of fire with the fuel system? I love back yard mechanics.
I personally think Meth injection is easier to do and gets 90% of the performance boost of running straight e-85. As far as the specific densities of ethanol or methanol and how to mix it with water to get exact 50/50 blend I don't bother with mixing it, I just run straight meth KISS.
I've seen 100's of cars running e-85 on stock lines with no issues. One specifically has over 40K miles with e-85 and no leaks or corrosion noticed.
This thread has been off track since the "My tuner said, headers loose torque down low" BS. Not even sure why the OP asked the boards if he was just going to do what his tuner said anyways.
