C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
P0300?
Old May 21, 2011 | 09:32 PM
MARSC6's Avatar
MARSC6
Default P0300?
Just went full throttle in 2nd gear and afterward I had a flashing CEL for a few seconds. When I scanned it I have P0300 pending which is random misfire.
Any ideas what would cause this?
Old May 21, 2011 | 10:50 PM
crownu2's Avatar
crownu2
On my Z06 it was 3 of the spark plugs went bad.....
Old May 21, 2011 | 11:16 PM
Jnape's Avatar
Jnape
Broken valve spring can.
Old May 22, 2011 | 01:54 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I agree with the two above and I'll add clogged cats to the list of possibilities.
Old May 22, 2011 | 07:47 AM
MARSC6's Avatar
MARSC6
On the drive home it felt and sounded normal. Before this I was at full throttle several times without any problems.
I'll try to go out this afternoon and see if it happens again.
I do have aftermarket high flow cats.
Old May 22, 2011 | 10:48 AM
tjwong's Avatar
tjwong
Check your spark plugs, make sure that they are gapped properly, and have no cracks in them. I have seen some plugs that get installed wrong where they get cracked during installatio which can cause intermittent misfires, especially under boost and higher engine speeds. Also double check your spark plug wire boots for holes and or cracks or ther defects. Any one of these can cause misfires under boost and high engine load and speeds.
Old May 23, 2011 | 12:37 PM
APSGTO's Avatar
APSGTO
PLUGS, PLUGS, PLUGS, PLUGS, PLUGS.......
Change them.
Old May 23, 2011 | 02:57 PM
MARSC6's Avatar
MARSC6
Did a couple short runs yesterday and everything was fine again.
If I get a chance this weekend I'll pull a few plugs to check.
Old May 23, 2011 | 04:22 PM
APSGTO's Avatar
APSGTO
It will happen again for sure. I just went through the same problem a week ago. CEL blinking(P0300) random misfire. Cleared it. Car idled and drove fine and didn't throw the code the next time I got on it. But a few days later it did it again. Long 3rd gear pull shift to 4th and shut down, light blinking again. The plugs are $1.98ea at autozone (TR6's) Gap them per ECS's specs and torque them to 11ft/lbs. Be sure to use anti sieze grease on the threads (liberally) and hand tighten all the way first before torquing them down.
Tools needed: Torque wrench; plug socket (can't think of the size off hand); a 3" extension for the torque wrench.
Meth is hard on the plugs, they should be changed every 9-10K miles.
Old May 23, 2011 | 04:39 PM
MARSC6's Avatar
MARSC6
The plugs are 3 years old now.
I guess I better change them before I need to break out the melted catalyst repair tool.
Old May 23, 2011 | 04:43 PM
East Tx Muscle Cars's Avatar
0East Tx Muscle Cars
Former Vendor
75% of the time its a plug
20% a wire
5% other stuff
Old May 23, 2011 | 05:01 PM
Robls6's Avatar
Robls6
As long as we are talking about plugs. How often should they be changed on supercharged cars? I've got over 15,000 miles on mine. The car runs fine, but maybe it could be better than it is now?
Old May 23, 2011 | 07:00 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
20% a wire
5% other stuff
Unless you have MSD wires, then you can switch the plug vrs wire percentages.
Marc, I would also say plugs or wires first.
Old May 24, 2011 | 04:20 AM
theofel's Avatar
theofel
St. Jude Donor '10-'13
I'm having a similiar problem with a NON FI 08 A6. But with an weird twist. This PO 300 code only happens in the D mode and then it goes into Limp mode. It does NOT happen in S mode. Just had the tranny rebuilt and NEVER had this problem before the rebuild. Does anyone have any ideas why this would occur only in Drive? If it were plugs or wires..I would think it would occur in both the drive mode and well as the S mode.
Old May 24, 2011 | 10:18 AM
BadAV's Avatar
BadAV
Really? I've had MSD Superconductors on my Magnacharged Avalanche for about 6-1/2 years now without a single issue. No misfires on any of my HPT scans.
Old May 24, 2011 | 10:59 AM
APSGTO's Avatar
APSGTO
Do you have meth? If you do I'd say if you don't have a misfire by 10K miles then change them at 10K miles.
These AC Delco wires you put on your cars are a quality product.
Old Feb 15, 2014 | 02:12 PM
Vital Velocity's Avatar
Vital Velocity
St. Jude Donor '11
Got our question answered
Old Feb 10, 2020 | 07:36 PM
omspray's Avatar
omspray
7th Gear
My po300 was caused by my torque tube !!! did plugs and wires then cleaned injectors replaced map maf crank and cam sensor , then found post about torque tube and sure enough I rebuit it and now all is well !!!
To P0300?
