■ LS7 Z06 E-Force Build ■
May 29, 2011 | 11:48 AM
Customer dropped his car and we are starting on his E-Force project.
First step will be stock baseline – from there the basic steps..
1) Remove Engine
2) Forged Pistons (-8 cc)
3) ARP Rod Bolts
4) Plate Hone
5) Deck
6) Line Hone
7) Balance and reassemble SB
8) SS Valves
9) Comp Valve Job
10) Dual Springs
11) ARP Studs
12) Assemble long block
13) Install back in Z
14) Install E-Force
We will post as it goes along. The results will be interesting as we can push the boost without fear of crumpling the cast pistons.
May 29, 2011 | 11:53 AM
Sounds like a cool project. What will the compression be? Are you going to pulley it down to see what it maxes out at?
May 29, 2011 | 05:58 PM
Quote:
Originally Posted by
mdaniel
We aren't going to run beaucoup boost on this so we're only taking the comp down to 10.0:1 - it will have plenty low end grunt and won't lack for top end, either.
May 29, 2011 | 06:02 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Sounds like a good project Charlie. What fuel system will you be using?
Jun 2, 2011 | 10:21 PM
Here are a couple of pics from the machining process in building the motor
The Block in the cylinder hone
[IMG]
[/IMG]
The Blance of the crank
[IMG]
[/IMG]
The crank after polishing
[IMG]
[/IMG]
The block on the stand ready for assembly
[IMG]
[/IMG]
Jun 3, 2011 | 12:47 AM
From: Greater Detroit Metro MI, when I'm not travelling.
I'll be watching this one
Jun 3, 2011 | 12:22 PM
austin@RPM
[IMG]
[/IMG]
That is beautiful!
Jun 3, 2011 | 12:55 PM
St. Jude Donor '11
Jun 3, 2011 | 01:56 PM
5 Liter Eater
How come stock rods?
We aren't after mega power on this build - and the factory ti rods are more than capable in this power range.
Jun 3, 2011 | 03:50 PM
What are your power goals for this build? Are you considering any intake manifold porting?
Jun 4, 2011 | 02:26 PM
we just finished the short block and here are some pictures of what she looks like.
One side of the motor
[IMG]
[/IMG]
The other side of the motor
[IMG]
[/IMG]
the bottom of the motor
[IMG]
[/IMG]
front shot of the motor
[IMG]
[/IMG]
Jun 13, 2011 | 05:53 PM
A couple more pics of the build
The cam being degreed
[IMG]
[/IMG]
Cam wired
[IMG]
[/IMG]
One head on
[IMG]
[/IMG]
New act clutch installed
[IMG]
[/IMG]
motor going into the car
[IMG]
[/IMG]
S/C unit on the car, just fits under the hood
[IMG]
[/IMG]
Jun 14, 2011 | 08:53 PM
Jun 14, 2011 | 09:03 PM
5 Liter Eater
Because that blower isnt going to support enough power to break them...
Beautiful engine though!
Jun 15, 2011 | 06:08 PM
Car is up and running. Doing some preliminary driving (break-in) and calibration mapping.
Special thanks out to Chris at Edlebrock for bailing me out with the proper scaling of the new 2-bar TMAP sensor...
Jun 15, 2011 | 07:06 PM
breecher_7
Jun 25, 2011 | 01:33 PM
Updates?
Where are the numbers?
Jul 8, 2011 | 09:20 PM
