C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E-force install on LS2, need help with tmap wiring
Old Jun 12, 2011 | 11:42 AM
Matco21's Avatar
Matco21
Default E-force install on LS2, need help with tmap wiring
I just finished the install on my E-force Ls2 and have 300 degree IAT. Does anyone have a wiring diagram for this kit? Mine did not come with one.
I do not know what pin is desinated for the IAT. It must be swapped with another pin in the wiring harness that came with the kit.
Can anyone help me out?
Old Jun 12, 2011 | 12:09 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
My install was just finished and it was found that there is some defective wiring harnesses with some LS2 kits. There are 2 pins that have to be swapped on one connection. It is the connection at the right rear of the manifold with 4 pins. I don't remember exactly which 2 have to be switched but edelbrock suppost is aware of the problem. You should call to see if that's your problem.
Old Jun 12, 2011 | 12:16 PM
Matco21's Avatar
Matco21
tried calling them yesterday but they are closed on the weekend. I am trying to get this figured out today.
but you are right the tmap is located on the right side in the back of the unit.
It seems they have been changing tmaps alot. that must be the problem with the wiring, the pins are in different locations on each tmap.
Old Jun 12, 2011 | 12:34 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I wish I remembered for sure but I don't. Possibly 2 and 4 that have to be switched. They are numbered on the connector. There is a tmap sensor change but they just started shipping so I doubt you could have the new one.
Old Jun 12, 2011 | 12:43 PM
Matco21's Avatar
Matco21
My sensor has the numbers ground off it. makes it hard to find any specs on it. but thanks for your input.
Old Jun 12, 2011 | 12:46 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
The numbers are on the eforce suppied harness connection if I remember. I remember that one of the wires to be switched is grey. That's all I got. Good luck
Old Jun 12, 2011 | 12:48 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Doesn't the PDF on the e-force site for installation help some how? Is this something that needs to be done on any new LS2 install?
Old Jun 12, 2011 | 12:52 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
No. Its not all. Just some harnesses have a defect.
Old Jun 12, 2011 | 01:02 PM
tjwong's Avatar
tjwong
Did you install the edelbrock tune It rescales the IAT scaling factor in the calibration to represent the new TMAP sensor.
Old Jun 12, 2011 | 01:05 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Didn't use the edelbrock tune. Don't forget I'm just suggesting you may have the same wiring issue I had. It also may be something totally different. The wiring issue did cause a strange iat reading though.
Old Jun 12, 2011 | 01:07 PM
Matco21's Avatar
Matco21
yes I loaded the box tune from edelbrock and did the latest update. I belive that the pin location is wrong for the tan wire (IAT).
can anyone tell me what the sensor they have looks like or says on it and the color order of the wires coming from it?
Old Jun 12, 2011 | 01:10 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
You art right as I said. The pins are mixed. I can tell youy the order a bit later. I am not with my car right now.
Old Jun 12, 2011 | 01:56 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Tough to see but looks like this to me starting from passenger side.
Orange
Yellow/biege
White/greyish
Green
Old Jun 12, 2011 | 02:00 PM
Matco21's Avatar
Matco21
Yeah that's how mine is but I might have a different sensor does yours have any numbers on it?
Old Jun 12, 2011 | 02:10 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Its the fomoco one. Ford item. If you wires are correct your problem may be elsewhere ? I thing they are all fomoco until what's shipping now. number hard to read but looks like
Aa5a-9f479-ca
Old Jun 12, 2011 | 02:35 PM
Matco21's Avatar
Matco21
Yeah mine is different. Definitely not ford. It says germany on it. I guess I will have to wait for edelbrock to open on Monday. But thank you for your help.
Old Jun 12, 2011 | 02:39 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
No problem. Did youy receive the unit recently ? I think they said change starting june as they can't get the fomoco piece anymore. Good luck. Let us know the results.
To E-force install on LS2, need help with tmap wiring
Old Jun 12, 2011 | 02:54 PM
Matco21's Avatar
Matco21
I received it on 5/31/11 but it must have the new sensor in it.
Old Jun 13, 2011 | 04:51 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
So ??? I'm curious what you figured out.
Old Jun 15, 2011 | 08:44 PM
Matco21's Avatar
Matco21
I spoke with Edelbrock tech support monday morning about the tmap issues I was having, the software calibration was wrong. Now I have that fixed but I am still having a low idle/stall issue when I come to a stop.
Everytime I call edelbrock now The system says " we are experiencing a high call volume please call back later." then hangs up. I have been calling since monday and still cannot get through. Very poor customer service.
Has anyone had this issue?
