C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Noisy E-Force Blower
Old Jun 24, 2011 | 06:38 PM
abstruse1's Avatar
abstruse1
Mrgillies, may be worth a try, but I've been told that the contact problem predated the C6, and I did take a piece of shirt cardboard and run it left to right between the blower and firewall. No apparent contact when motor at rest.
Old Jun 24, 2011 | 06:48 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Its definitely not normal to have noises like that. Mine has been on for about 1000 miles now and I haven't heard anything unusual. As was mentioned they added installing spacers for added firewall clearance but I'm not sure if that is just an LS2 issue. Good luck in solving the issue and please keep us posted. Its funny how once I start reading a thread I always want to know the outcome, even if its not relevant to my car.
Old Jun 25, 2011 | 03:29 AM
mrgillies's Avatar
mrgillies
I have a noise as well, here is what I've done so far:
Installed carboard between SC and firewall and ran the vehicle, no change in tone
I have Beehive installed, made sure there was no rubbing contact
I have noticed that if the I'm in neutral and rev the engine, the noise/vibration isnt there.
My issue must therefore lie in the exhaust system
Steve
Old Jun 25, 2011 | 05:04 AM
Jennifer @ TPE's Avatar
Jennifer @ TPE
St. Jude Donor '12
Not necessarily...
When you free rev the motor, the load isnt there. The lack of load causes the blower to stay predominently in vacuum. You may touch on the boost when you rap the throttle, but regular reving keeps the blower in vacuum. You "Might" only be seeing this when the motor is either at close to boost, or actually in boost. You need to check and see if it is boost dependent.
For the purposes of testing, you can force the bypass closed, keeping the blower in boost. We do this by putting a ziptie on the bypass plunger. Then re-test your rev procedure. You can also drive for a half mile or so. Just do not push the car for more than about a mile.
constant boost at low throttle position can prematurely overheat the head unit and damage it if you drive any length. A mile or so is perfectly fine.
Jennifer
Steve
Old Jun 25, 2011 | 11:36 AM
71'AirStrike's Avatar
71'AirStrike
Ohh, Nice Tip Jennifer!
Old Jun 25, 2011 | 01:46 PM
mrgillies's Avatar
mrgillies
Great tip, but no joy, SC sounds great when not driving, holding it open (zip tie) and reving past 4K there is no noise apart from the lovely SC sound, so it must be something like the exhaust
Hey 71'Airstike, we're neigbours...
Old Jun 26, 2011 | 11:08 PM
BillB3672's Avatar
BillB3672
I have been thinking about installing the E-Force on my 11 GS, but from this thread it sounds like A&A is the way to go. SC's should not make these type of noises. It may be an external issue, but don't want to be in the R&D group for any supplier ! These units have been on the market for a couple of years, so I would expect these type of issues would be resolved by now.
Old Jun 27, 2011 | 11:48 AM
mrgillies's Avatar
mrgillies
Well I'm at my wits end, I have taken both coil brackets off, checked the SC is on the head correctly, tucked the wires under the the top part of the coil bracket (per instructions) made sure injectors are not making contact with anything, all other pipework (brake booster, pcv intercooler return and fuel) are clear and not obstructing anything.
Checked my exhaust and that is clear and tight from manifold down.
To be more descriptive here is what I'm hearing
Low power demand <15% : No noise whatsoever in all RPM's
Medium power demand <30% : Water bubling sound in front of dashboard
Higher >30% : Vibration sound, coming from front of dashboard, possible water hammer?
So from this, It sure seems like the intercooler return could be a possible suspect, I have checked the intercooler pipework and it all looks clear, where the both return line goes round the rear there it does contact the rear firewall but there is no way around this, it does move freely up and down though. I have also ran the engine with the cap off the intercooler resevoir to remove any air pockets, you would have thought they would be gone by now seeing as its a closed system with supply from the bottom of the tank.
Any ideas?
Steve
Old Jun 27, 2011 | 11:52 AM
mrgillies's Avatar
mrgillies
Did you open the post that Motorhead47 put up with the utube video on a Centri first start up, wwhen comparing that @ idle to the e-force,, e-force has no noise whatsover. I'm sure my noise issue is going to be a simple fix.
Old Jun 27, 2011 | 12:21 PM
NYC6's Avatar
NYC6
Originally Posted by Motorhead-47
Are you sure thats a T trim? I have one on mine and its not even remotely close to that one! I know its difficult to compare sounds against a video but thats not representive of a T trim as far as my exp has told me.
Old Jun 27, 2011 | 01:37 PM
mrgillies's Avatar
mrgillies
Ok, time for an update, called edelbrock who were extrmely helpful, they have probably hit the hammer on the head for me anyway, we discussed my install and I told them I replaced my radiator and that noise I'm hearing is most likely air trapped in the engine, the noise could be coming from the heater coil inside the dash, so the system requires to be bled, so I'm going to try that, I'll keep you posted once I work out how to do that.
Old Jun 27, 2011 | 01:42 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Sounds very possible. Its tough to get all the air out properly without using the right equipment when you fill the coolant. Hope thats it.
Old Jun 27, 2011 | 01:49 PM
  #33
mrgillies's Avatar
mrgillies
In case anyone wondering how to purge air out the "closed system"
From Motorhead-47:
Simple technique to purge air from the cooling system. …There are two hoses on the overflow tank. Follow the smaller/upper one until you reach it’s junction point. Remove that connection. Fill the overflow tank and put the cap on tight. Blow into the overflow tank via the line that your removed. This will force coolant from the overflow tank into the cooling system. When the tank is empty, refill and repeat. Continue doing this until fluid begins to exit from the other end of that hose connection you removed. Reinstall hose. DONE! Works like a charm!
Typical Motorhead-47 to know everything...
Steve
Old Jun 27, 2011 | 06:38 PM
  #34
Motorhead-47's Avatar
Motorhead-47
From Motorhead-47:
Steve
I wrote that one quite a while back. You can call it shadetree or hillbilly or ghetto but the fact is it is a simple and effective way to fill the cooling system. Just a couple of additional details...you are following that upper line along the top of the radiator until you reach a "T" junction. That is where you disconnect it. Obviously you want to do this with the car cool. After X evolutions of fill, blow, purge, fill...you'll know it is full when coolant starts to burble out of the "T" fitting. After I'm all done I usually fill the coolant tank about 3/4 full and drive the car and then recheck. I also recheck again after the car has had a chance to cool down completely. It works! I've done this way at least a dozen times and never had an issue and rarely add more than a couple of ounces after the cool down recheck....sometimes get some funny looks from friends as I do this though!
Old Jun 27, 2011 | 06:42 PM
  #35
mrgillies's Avatar
mrgillies
I like doing hillbilly, as long as it gets'r done. Hope it get too messy though.
Old Jun 27, 2011 | 06:45 PM
  #36
mrgillies's Avatar
mrgillies
One quick Q... What type of pressure are we on about 20psi?
Old Jun 27, 2011 | 09:46 PM
  #37
Motorhead-47
Are you asking about radiator pressure or supercharger boost pressure or your good ole lung pressure to push that fluid through the cooling system with?
To Noisy E-Force Blower
Old Jun 27, 2011 | 09:48 PM
  #38
Motorhead-47
Oh and to state the obvious...you perform that procedure with the car shut down...not running!
Old Jun 27, 2011 | 10:24 PM
  #39
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
This procedure works very well. NOTE: Dexcool has a very bitter taste.
Old Jun 28, 2011 | 12:28 AM
  #40
mrgillies's Avatar
mrgillies
Ah well, thought all was good; purged the vehicle cooling system per instructions for about 5-6 times, test drove the vehicle, for 3-4 mins and all seemed great, then the noise started coming back to the same as before....
Maybey I need to purge again?
