C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Need advice
Old Jul 5, 2011 | 10:00 PM
Ryan07's Avatar
Ryan07
Default Need advice
I have a 2007 C6 that I've added an A&A T-trim kit to. Because we don't have too many experienced (LS) tuners on island, I went with a tuner that was recommended on the mainland and sent datalogs/tunes back and forth. I've run into a problem with the MAF maxing out at 5400 rpm. I put the car on the dyno today and she pulled a mere 446/416 (5400-6500rpm)on 92 Octane and 7lbs. The lines are nearly straight until it hits the 5400 area, then she flatlines and breaks up.
Is it normal for the MAF to max out so early on such a moderate amount of boost? Do people usually change the MAF to a card style like the LS3/LS7 or do the just go speed density? I'd really like to keep the car tuned with the MAF.
Thanks,
Ryan
Old Jul 5, 2011 | 10:09 PM
Streetfast's Avatar
Streetfast
No that is not normal. I'm sure some of the tuners will respond. Good luck.
Old Jul 5, 2011 | 11:29 PM
DSteck's Avatar
DSteck
Something doesn't sound right. The MAF shouldn't be running out at that power level. Are you using HP Tuners? Do you have a wideband you can install into the exhaust and connect to the interface?
Old Jul 6, 2011 | 01:16 AM
Ryan07's Avatar
Ryan07
I am using HP tuners. I didn't have the Wideband hooked up for the dyno, but if I remeber right from the last datalog (after the tune was finished), the car goes from 11.6 to 9.99 or so at 5400ish. I don't have the laptop with me, but I can get it later tonight.
I am flying out to Phoenix on Thursday and won't be back before the last week of the month. Was planning to talk with some of the shops there.
Can anyone tell me the difference between a loaded and unloaded Dynojet? I was told the shop had a loaded Dynojet, but when I asked the guy running it if he could make one pull without a load, he said it wasn't loaded and explained that it was standard SAE readings. It might make some sense if the dyno were a loaded one and gave "real world" power that you would see day to day on the street, but not if it were a standard pull.
Thanks for the help.
Ryan
Edit: the WB was reading low 11 high 10s, then progressed to low 10s before the MAF maxed out.
Old Jul 6, 2011 | 03:20 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
What Island?
Old Jul 6, 2011 | 03:23 PM
White_06_A6_C6's Avatar
White_06_A6_C6
dollars to peso's if you post the tune up they probally PE raped it to death around that RPM and the breakup you see is you drowning the spark out.
Old Jul 6, 2011 | 05:03 PM
Ryan07's Avatar
Ryan07
Steve: I live on Oahu
White_06_A6_C6: I am on my phone right now. I can try to post the tune later. Do I need a site to host it first?
Old Jul 6, 2011 | 06:04 PM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
Post the logs as well. If it is under 2 meg you can upload it with your post from your desktop computer...
What year model is the car?
Old Jul 6, 2011 | 08:18 PM
Ryan07's Avatar
Ryan07
Doesn't look like I can attach anything. Under my posting rules at the bottom of the reply window it says "You may not post attachments
Ryan
Old Jul 6, 2011 | 09:15 PM
Ryan07's Avatar
Ryan07
My car is a 2007
Old Jul 6, 2011 | 09:35 PM
Ryan07's Avatar
Ryan07
Since I was unable to upload here. I've uploaded files to HPtuners site http://www.hptuners.com/forum/showth...687#post261687 .
Ryan
Old Jul 6, 2011 | 09:44 PM
magls2's Avatar
magls2
Try photobucket as a host site
http://forums.corvetteforum.com/help...al-inside.html
For photos only
Old Jul 7, 2011 | 07:00 AM
Ryan07's Avatar
Ryan07
I've used Photobucket before for pic. I think they host video now. Don't think the host files though. I'll check.
To Need advice
