C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Ls7 clutch
Old Aug 17, 2011 | 04:55 AM
djwho's Avatar
djwho
Default Ls7 clutch
Hi I need a new clutch on my ls2 c6 was thinking of going with a ls7 clutch with a ram fly wheel my car makes 560rwhp don't drag or track it jus for street use thanks for the info
Old Aug 17, 2011 | 05:22 AM
winters97gt's Avatar
winters97gt
Since you don't track your car, the ACT twin disks is a good choice. Good feel and does the job at a reasonable price for what you are looking for. Don't expect a long life out of any organic clutch if you do burnouts and slip the clutch, which you don't seem to do. I like the Mcleod RXT quite a bit over my ACT which lasted a few thousand miles.
Old Aug 17, 2011 | 05:42 AM
djwho's Avatar
djwho
I jus want something that will last long time for street driving I do sprint around a lil bit but that's all I dunt do burn outs or track my car I usually jus use my car for cruising around the city
Old Aug 17, 2011 | 05:48 AM
winters97gt
ACT twin.
/thread.
Old Aug 17, 2011 | 08:09 AM
Robls6's Avatar
Robls6
Try the Katech, or RPM LS9 clutch. That's what will be going in my car once the LS7 clutch in my 570rwhp car gives it up. So far though that little LS7 is taking everything I throw at it. Oh.... and I don't ever suck the fluid out of the reservior with a turkey baster either.
Old Aug 17, 2011 | 08:16 AM
MARSC6's Avatar
MARSC6
Check with ECS about this clutch they just started using this year. I believe its a mantic. Supposed to be very good on the street and handle power well. I'm hoping to get one in before next spring.
http://forums.corvetteforum.com/c6-t...-for-info.html
Old Aug 17, 2011 | 09:05 AM
Matt @ ECS's Avatar
0Matt @ ECS
Former Vendor
The Mantic Clutches are great.. As Mars said go ahead and check out that thread. If you have ANY questions feel free to PM, email, or call us.
Old Aug 17, 2011 | 12:44 PM
djwho's Avatar
djwho
Ls7 clutch is 500 dollars with a new fly wheel. What are some of the prices of these other clutches? Also should I be changing my flywheel? I'm a newibie get all my info off this forum lol
Old Aug 17, 2011 | 12:51 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I plan on the LS7 when I need to change the clutch. I want smooth and no chatter. Were I running higher HP, I would get the LS9 clutch.
Elmer
Old Aug 17, 2011 | 12:54 PM
Robls6's Avatar
Robls6
Definitely change the flywheel. When you order a clutch, it comes as a complete unit that is zero balanced as a whole package. When you mix and match components you run the risk of vibration issues.
Old Aug 17, 2011 | 01:06 PM
djwho's Avatar
djwho
Yah I was think ls9 but it ends up being a lil expensive! It's also going to cost me 1300 to get it installed
Old Aug 17, 2011 | 01:10 PM
breecher_7's Avatar
breecher_7
Im going to be the black sheep in the group and tell you to buy a SPEC 3+, its more clutch then you will ever need with your current setup and we have had great luck with it. If money isnt an option, i vote for the Katech LS9 Clutch, but the spec is pretty cheap in comparison.
Old Aug 17, 2011 | 01:11 PM
winters97gt
Hated mine. Wanted to drop it from a 10 story building.
Old Aug 17, 2011 | 01:33 PM
DSteck's Avatar
DSteck
If you have money, go with an RPS full carbon. After that, I'd look at the LS9X clutch. If that's still too much, you can try an LS7 clutch, but it'll have a hard time surviving for long at 560whp.
Old Aug 17, 2011 | 03:08 PM
breecher_7's Avatar
breecher_7
They are picky, somtimes you need to shim the slave. I know we had to. As well as a Tick Master cyl... Worked flawlessly behind of 800bhp on my buddies car though, for years.
Old Aug 17, 2011 | 03:12 PM
djwho's Avatar
djwho
Any idea on how long a ls7 can last? Like how many miles do some of you guys that do have one have on it?
Old Aug 17, 2011 | 03:32 PM
breecher_7's Avatar
breecher_7
Lets put it this way, unless im a moron, the LS7 clutch is the same one they put behind the LS3 and I have seen near stock LS3 cars destroy them pretty quickly.
To Ls7 clutch
Old Aug 17, 2011 | 03:46 PM
MARSC6's Avatar
MARSC6
The LS7 clutch may be cheaper now.
Untill you have to replace it and pay for another clutch and all that labor for a second time.
Old Aug 17, 2011 | 04:57 PM
winters97gt
Do it right the first time.
Old Aug 17, 2011 | 05:17 PM
LEAVINU's Avatar
LEAVINU
All the more reason to get the right clutch this time around!
I would atleast look at the LS9 assembly from Katech. Cost more than the LS7 but I'm pretty sure you won't need another clutch for a very long time based on your driving style described above.
